Old August 13th, 2019, 10:42
Rod Knee's Avatar
Rod Knee Rod Knee is offline
Rough idle problem with blower motor malfunction
Iím having a strange issue with my xj. Six weeks ago frame stiffeners were welded to the jeep at local shop. A rough idle was immediately noticed. A mechanic I took the vehicle to corrected a vacuum leak and I thought the problem had been rectified. Then while offroading, the idling problem reoccurred and blower stopped working simultaneously once it started raining. I have hood louvers.
The strange thing is the rough idle only occurs when the vehicle is in D and the switch for the blower motor for a/c and heat in the cab is not on the off position. The vehicle stalls in this situation when braking for a stop sign. I can make this problem disappear by turning the air conditioning/heater/defrost/vent switch to the off position.
Anybody had a similar experience? From my understanding the blower motor and idle control have nothing to do with each other. The throttle body is clean and so is the IAC sensor. I replaced the blower motor and resistor yesterday. Maybe the welding on of the frame stiffeners resulted in a wiring problem (?). The problem occurs immediately upon starting the vehicle when cold so I'm thinking its not heat soak effecting the injectors.
Any ideas?
1996 xj, automatic transmission, 4L straight 6
Old August 13th, 2019, 20:24
lawsoncl lawsoncl is online now
Re: Rough idle problem with blower motor malfunction
Check all the ground cables, especially between the body and engine at the back of the firewall, and from the bolt by the dipstick to the battery. If the welder clamped his ground to the battery or some random place on the body, he could have burnt a ground cable or connection.
Old August 14th, 2019, 10:05
Rod Knee's Avatar
Thanks. My mechanic is going to check voltage drop in a couple days which, as I understand, could indicate a bad ground.
replaced heater core, now blower motor problem YFZsandrider OEM Tech Discussion 5 August 20th, 2013 19:26
Blower Motor Problem sixty7ss OEM Tech Discussion 20 September 2nd, 2012 12:04
New Blower motor problem.... and I searched Cherikon OEM Tech Discussion 2 September 28th, 2011 20:25
ZJ blower motor problem RNMedic Tow Rigs and Trailers 0 January 26th, 2011 15:46
2000 XJ Blower Motor/Circuit Problem tsc OEM Tech Discussion 0 February 10th, 2005 17:37
