Go Back   NAXJA Forums -::- North American XJ Association > Land Use / Off Topic and other Forums > Tools and Garages
Tools and Garages This is a place to share about the tools and workspaces used to craft your latest masterpiece.
  #16
Old October 1st, 2018, 07:13
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
Re: welder options for xj things, newb here
I've been doin a lot of research on this as I'm not rushing into buying this tool.
I have seen aev review on the Vulcan, he didn't speak that highly of it's build. For the money I believe there's better options, but thank you kindly for the recommendation!
Old October 2nd, 2018, 15:06
Bent's Avatar
Bent Bent is offline
Only Slightly Psychotic
Just keep your eyes peeled for a Millermatic 210 and call it a day. Old enough to help make the price come down and it'll do 3/8" when you need to. I've had mine since new, run .035 wire and never had an issue.
Let someone else pay the depreciation; that's what I did with my buzz box.
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ • 4.0 • AW4 • 231 • Modified
'87 MJ • 4.0 • AW4 • 231 • Stock-ish
SoCal Chapter Past President
Old October 7th, 2018, 09:43
Hypoid's Avatar
Hypoid Hypoid is offline
Check with Welding Supply stores in you area.
My former employer used the General Air store in Denver. They had used machines for sale, they back their product, and service what they sell.
The Lost Boys' motto: We don't know where we are going, but we'll be there for awhile...
Old October 11th, 2018, 12:38
LLLux31 LLLux31 is offline
Oh I forgot to mention you can also try it for up to a year and return it no questions asked within that one year.
Old October 12th, 2018, 13:09
MrSimon MrSimon is offline
Your best bet is a local store. They will give you good advice on a machine that fits your needs and budget. They'll also set you up with tanks, tools, and accessories.
Take it home and start welding.
Old October 17th, 2018, 20:55
Heavyopp Heavyopp is offline
This isn’t entirely true — I have a local airgas that will just plain run a newb right out of the store
I know I’m late to this thread but let me make some suggestions
1st of I’ve been welding for 25 years — never as a profession but I have made some money — enough to have paid for my equipment
I started out with a Lincoln weldpak 100 bought at price club - that’s Costco for you young guys — did a ton of work with that machine, easily weld 3/8” material with multiple passes — That welder was around for 10 years — remember that this was before the big box store welders — they are just not the same as a welder from a welding supplier
Shortly after the weldpak 100 I purchased a miller 250G engine driven machine — the weldpak 100 got me started, I soon realized I really enjoyed welding and it was time for a bigger machine but I didn’t have the electricity required to run a bigger machine — shop only had a 30 amp service
The 250g was a stick welder, mig welder with a spool gun, and a tig machine which could run AC for aluminum welding with the addition of a high frequency box — I had it all, acquired over some time — I still have this machine use it at that same location with limited power
When the Lincoln died I replaced with a miller 211 — this is a great welder — runs off both 110 and 220 and it’s plenty capable — weld exhaust pipes and sheet metal, then do 3/8 material with 1 pass
I also have a miller 280DX inverter machine — tig and stick weld with it — this machine is the cats ass
The point of all this — buy the most welder that you can afford no matter if you can use it or not — if you enjoy welding you’ll learn how to use you machine — don’t outgrow your welders capabilities, grow into your welder — if you find welding isn’t for you, you can always sell quality equipment for very little loss
I would strongly suggest the Miller 211 as your 1st welder
I would also suggest a quality auto dimming helmet with a large window — you must see what you are doing — spend $200 plus on your helmet
Old October 19th, 2018, 09:15
Yeah the place where I get my gas always makes me feel like I'm bothering them when I ask about a recommendation between a few products they're selling. Example antispatter nozzle gel vs spray.
Old October 19th, 2018, 18:57
I have no suggestion with the antispatter stuff — in 25 years of welding I’ve never used a drop
Old October 20th, 2018, 09:15
Bent's Avatar
Just say, "I'm sorry for acting like a customer ". That usually changes their attitude. In certain situations I'll say,"why not pretend that you're getting paid by the hour ".
Old October 20th, 2018, 09:21
Lmao those are great.
Old October 21st, 2018, 23:11
Fairly certain I'll go with the Lincoln 3550 for a hood. Was strongly considering the Hobart 190, then many users recommended the hh 210mvp for a little more juice and power 110,220 versatility. For that coin I'm knocking at the door of a mm211 lol so I'm leaning uphill a bit, I do agree a better welder would likely resell for fair coin. The only reason to consider Hobart would be to stick with a transformer machine, I read so many mixed reviews, but ide imagine new Miller inverter tech is fairly robust at least for my needs.
I will check out some local suppliers. Most mm210/212 aren't dropping in price on the used market around here.
Let's take it one step further, Anyone using the Miller 215 as it is a multi process machine?
Just curious really. I don't plan on stick/ tig, but wondered if you all prefer individual machines for those purposes?
Old October 22nd, 2018, 18:40
Anak's Avatar
Anak Anak is online now
Stranger
Every process has its pros and cons, and machines do vary in how they perform.
I have two stick machines. One is a Lincoln tombstone (classic old 240V buzzbox) and the other is a Miller Trailblazer (gas engine driven). The Miller Trailblazer has a much smoother arc than the Lincoln tombstone.
I was also very impressed with how smooth a Miller 211 (and only on 120V) was compared to my Lincoln SP135+ (similarly sized MIG machines).
I am very happy with my Lincoln TIG275. It beats the pants of the old Linde I learned on. But for the price it dang well should too.
Having all three systems available to me, I really would not want to give up any of them. The stick is what I least prefer to use, but if I have to weld outdoors it is the only shielding that really works. The TIG is expensive and had a steeper learning curve, but there is no substitute if you really need control of heat and the rate at which material gets added, plus no spatter with TIG. But I will say the MIG is the quickest and most convenient, as long as it suits what I need to do.
WRT to the welding helmet, I am going to guess you mean the Lincoln 3350 as 3550 doesn't show up on my search. That looks like a reasonable choice. One of my key details is that it have replaceable batteries, and it would appear that one does. Make sure you buy a spare set of batteries before you actually need them. It will probably be a couple of years before you do need them, but know that you eventually will. Being able to replace them sure beats needing to replace the hood. DAMHIKT.
Old October 23rd, 2018, 20:18
You don't plan to stick/tig today but if the welding bug does find you...
I personally would have individual machines for the different processes -- Sometimes I'll tack something together with the mig then go full blown stick weld on it to finish it off -- Usually do this on heavy material like 1/2 plus steel where the 211 just isn't enough machine
Keep in mind my Miller 211 is a transformer machine, I was in before they went inverter on that so I have no comments on the inverter version
My 280 is an inverter machine -- kind of nice to be so compact with all that power -- a full 280 amps I believe
Your best bet is a dedicated Mig machine -- I like miller but there are plenty of guys who like Lincoln too
Old October 30th, 2018, 08:13
There are some decent rebates going on with miller and lincoln right now
Heres a little article comparing lincoln and miller muti purpose machines:
https://www.weldingsuppliesfromioc.c...sourc e=zaius
Old December 22nd, 2018, 17:34
Pulled the trigger on the mvp210 and Lincoln 3350 hood.
Couldn't pass the welder at the 700$ price for the holidays, plus I got the hood brand spanky N.i.b. from a guy for 200$.
Ide say not too bad a setup for a newb, plenty of room to learn.
I'm very happy with the quality of both pieces of equipment, they perform very well.
Rate This Thread:
Ready welder 2 portable trail welder JohnX SoCal For Sale 6 June 8th, 2018 18:37
Mini-Welder 115v welder/carbon torch, Front OEM skid and other stuff Bent SoCal For Sale 9 January 22nd, 2016 16:17
Welder (True Options) 98XJLongBuild Tools and Garages 8 March 29th, 2012 08:47
a few things for an XJ newb deathwobblezj Wanted: Private Party Only 0 February 14th, 2005 04:51
ready welder/century welder/portable welder? Redcbr007 Wanted: Private Party Only 1 June 6th, 2004 22:01
