Clutch Reservoir issue
Nomad Nate
San Diego
Hello all. I have 91 XJ with the AX-15 transmission. I noticed it was a little tougher to put it in gear and checked the clutch reservoir. It’s pretty much empty and from the looks of it the PO replaced this at some point.
It doesn’t have a full line and the cap doesn’t have plug. I’m not sure how high I should fill. Also I assume I’ll need to bleed it as well since it so low. Any suggestions are appreciated.
Empty is not good.
First question is where did the fluid go?
Since the most inconvenient option would be the slave (internal to the bellhousing on a 91, right?) that is probably the problem.
As to the fill level, pretty much up to the top.
Maybe (real long shot) you have lost your fluid out the top. I think you are supposed to have a rubber seal with a diaphragm that expands down into the fluid (like on a brake master cylinder). I don't know if you can get that part separately. Might have to hunt for another in the JY. If not in an XJ, try a Dakota or a Ram with a clutch--those might interchange (at least the seal).
Empty is not good.
Thanks. I’m definitely concerned with where it went. I refilled it but couldn’t get it to bleed. I took it around the block and the clutch felt much better.
I will dig further into this of course but curious if I’m going to cause damage if I drive more before I bleed it. I feels good and shifts fine for now at least.
I don't imagine you are in danger of doing any measurable damage to the system, provided it seems to be shifting fine.
