Old September 18th, 2010, 00:36
DSteveXJ DSteveXJ is offline
Burning smell maybe?
So I finally got my 88 XJ 4.0L started on Thursday. it was sitting for around 8 months to a year the kid who had it before me blew the tranny and just let it sit.
Well I had to replace the plug wires, distributor cap, rotor, ignition coil and I also put in new 10-40 oil and a little over 5 gallons of 92 octane gas to help out the gas that was in there.
To also get it started I put in a oil squirt can some tranny fluid and squirted about 5-6 squirts of tranny fluid into each cylinder to give it a little lube to get going. And well after all of that it fired right up and is going good.
I also filled up the reservoir tank with new radiator fluid and power steering fluid.
The temp gauge goes up to the 210 mark and the mechanical fan kicks in and cools it back down I DO NOT HAVE AN E-FAN AS I DON'T HAVE A/C the oil pressure gauge is broken but the engine doesn't sound like a lawn mower so I have oil pressure. I don't see any leaks of any kind except for all of the tranny fluid on the underside due to the bad tranny.
Now when I start it and it sits for about... oh id say 10 minutes or so give or take a couple minutes the belt starts squealing (not 100% but kinda sure) it starts soft and gets louder as it runs to the 10 minute mark and I start to see smoke/steam whatever it is coming up from the drivers side of the valve cover gasket, now I'm not for sure if its coming from the valve cover itself, but it looks like to me that it comes from that point of the engine. And for what I've looked at (which I haven't looked much) I haven't noticed any burning or hoses.
It smells like a burning of rubber/plastic hell it might even be oil or tranny fluid but I can't pin point it myself and since I just bought it I really don't want to buy a new engine or something. The smoke isn't a thick smoke just transparent like in color.
Thanks for any help you can give to a first time Jeep owner!
Old September 18th, 2010, 11:33
lawsoncl lawsoncl is offline
Re: Burning smell maybe?
You check the lines for the tranny cooler for leaks? I'm just thinking maybe the smell is just tranny fluid on the exhaust and/or belts.
Old September 18th, 2010, 11:41
joe_peters joe_peters is offline
Ok, you need to locate the source of the sound.
Three feet of vinyl tubing, 1/2" I.D. or less, stick one end in your ear and move the other end around the front of the engine to locate the source of sound--WARNING: contact between human flesh and/or clothing with moving engine parts leads to loud screaming, cussing, and possibly spilled blood.
An alternative is to remove the belt and turn all idlers and belt driven accessories by hand. Listen and feel for any roughness, check for wobbling of the pulleys, etc.
Old September 18th, 2010, 13:38
The sound I believe is coming from the idler pulley at the top, passenger side straight top in line with the spark plugs. I put my ear to the pulley and it was the loudest when I was just over the pulley itself.
I hear those pulleys go bad a lot so that's the first thing I'm thinking of right now.
Old September 18th, 2010, 13:52
I'd pull the belt and give that pulley a spin. I think the whole pulley is under $20 at the autoparts place. Or you can press out and replace just the bearing. It's a pretty common size (6203-2RS I think, but don't quote me on that)
Old September 18th, 2010, 16:52
I'm going down to the autozone to get myself a new pulley and serpentine belt as we speak.
Will update once I get it alll replaced
Old September 18th, 2010, 20:34
Ok maybe someone can please specify as to what the valve cover bolts should be torqued down to??
I was told 11 Ft lbs then my haynes manual says either 22 for some of the bolts 45 for the others and then 100 for bolt number 11.
What is the real torque that they should be set at?
And remember I have the felpro gasket which doesn't need and sealer just put it on and your done.
Old September 18th, 2010, 21:37
92jeepxjOR's Avatar
92jeepxjOR 92jeepxjOR is offline
55 in lb
Old September 18th, 2010, 22:06
Thanks I actually just finished because my quartz lamp just blew the bulb but all I did was hand tighten them I will tighten them a little bit more tomorrow when I can see.
Old September 18th, 2010, 22:22
You are quoting part of the head bolt torquing sequence.
Please, please, please destroy the Haynes manual--it is the SPAWN OF EVIL, full of deceitful lies/errors/omissions. The path to H*LL is lined with Haynes manuals.
You can purchase a LICENSED copy of the FSM for your 88 on CD for less than $37 dollars. The manual is in PDF format, can be copied to your hard drive, and you can print/search. Here: http://www.autobooksbishko.com/searc...=Shop+Manua l You can also sometimes find the Bishko CDs from vendors on eBay a little cheaper when s/h is all figured up.
Old September 18th, 2010, 22:24
High intensity bulbs will blow quite rapidly if you touch them with your bare fingers or get any oil contamination on them.
Old September 18th, 2010, 22:27
Originally Posted by 92jeepxjOR View Post
55 in lb
Correct, 55 inch lbs.
Old September 18th, 2010, 23:07
Sweet thanks ill have to get a copy of that for myself. Do they make it in book form also? I like books more and plus my computer is broken.
Wow I'm only 23 and I just made myself sound like I'm 60 haha
Old September 18th, 2010, 23:15
Yep, they have the LICENSED manual reprints in book form, but they are going to run you quite a bit more. They are on the same link I posted earlier.
Old September 19th, 2010, 13:26
AAHHHHH. I can't for the life of me get the serpentine belt back on the XJ jesus christ this sucks I don't know and or can't relieve any tension just to get the belt on.
I've searched but I can't find anything pertaining to my XJ
Burning smell from a/c ? copper_blue OEM Tech Discussion 3 July 18th, 2008 18:57
Burning Smell sublime600 OEM Tech Discussion 2 February 15th, 2008 09:59
burning smell 88xjchief OEM Tech Discussion 19 July 16th, 2007 07:15
aw4 burning smell? ttms91xj Modified Tech Discussion 4 October 23rd, 2005 18:42
Burning Oil Smell BIGSLVRXJ OEM Tech Discussion 4 July 9th, 2005 16:58
