X-Earth05
- Lafayette, IN
Had the thing for a little over 2 years now, its been fun but I really don’t have the much spare time for it so it just sits around and I’ve decided to get rid of it. I was told by the guy I bought it from that the engine was rebuilt at some point but I can’t be sure. It runs and drives fine. I have the title and it is streetable, I’ve driven it to Redbird a few times with no issues but its really more suited as a trail rig.
The Good:
3 90%+ 31” Goodyear MTRs
1 Like new 31” Treadwright Gaurd Dog MT - similar pattern but not identical to the MTRS
1 BFG AT 31” spare
-3.5” lift - Rusty’s full leaf packs in rear, Longer coil springs (from a Mercury Cougar) up front with longer control arms from a ZJ rear (they aren’t any stronger than stock but they are the same length as aftermarket arms). It rides pretty nice and there is no death wobble.
-Rough country quick disconnect sway bar links
-CB wired in but the antenna broke off and will need to be replaced.
-I replaced the brake rotors, pads and front u-joints when I bought it so they should all be in good shape.
-Newer muffler
-Front and rear 2” receivers for recovery.
-I’ve overhauled the coolant system but I think there is a small leak somewhere because if it sits for months I have to add coolant and bleed the system. I’ve replaced the following:
Fan clutch
Radiator,
Water pump
Head gasket
Lower rad hose
-The AC compressor has been removed and the alternator has been relocated to the top to keep it out the mud.
-Comes with a spare set of rear glass
The Bad:
-Cosmetically the body is pretty terrible, rockers and rear lower quarters are shot. The frame rails themselves are still solid.
-Neither rear door works from the outside
-Cracked windsheild
-Gas tank has a leak if you fill it more than half way. I have a replacement one with straps that comes with it.
-One of the rear upper shock mount weld nuts is stripped.
-Neutral safety switch has been bypassed.
-Carpet in the rear drive side had a quart of oil leak onto it.
-Rear Passenger tail light is cracked.
-Both rear view mirrors are broken.
-The passenger side window falls off the track if it is rolled all the way down so there is a block of wood preventing it from rolling all the way down.
-Passenger side rear blinker wiring has some issues, it stays solid and doesn’t blink. I never looked into it so I have no idea why.
-Passenger side rear bumper mount is broken so it's hanging on by the drives side only.
-Slow power steering leak
-Oil pressure gauge just went out
-It looks like a bunch of idiots got drunk and just started spray painting it because they thought it would be funny.
May consider swapping just the wheels & tires for the right price.
Maybe interested in trading for/towards: plasma cutter, tube bender, chop saw, air compressor, 2.5x14 Reservoir shocks, Nitrogen bottle and regulator for shock refilling, Gooseneck 2 or 3 car trailer, Rigid or Vision X LED light bar, firearms, 5-point racing seats, go kart(s) etc.
If someone wants more info or pictures send me a PM. It's located in Lafayette, IN. Feel free to make me an offer.
The Good:
1 BFG AT 31” spare
-Newer muffler
Fan clutch
Radiator,
Water pump
Head gasket
Lower rad hose
The Bad:
-Cracked windsheild
