Modified Tech Discussion Forum for Tech related discussion for Modified XJ's and MJ's. |
Thread Tools | Display Modes |
Sliders
How are you guys bolting your sliders to the frame rails? how many bolts are you using on the pinch seam?
#2
Re: Sliders
As usual, the answer is 42. |
#3
Re: Sliders
But it still doesn't fit the question....wanna grab a beer? I know a grewat place at the end of the galaxy.....he he he. I thought I was the only one still alive that had read that series! |
#4
Re: Sliders
Re: Sliders
I had the DayStar Four Real tubes on mine till I bent the piss out of them. Per side they had 4 in the frame rail and 2 on the pinch seam. Tore them off regularly.
![]() Plated the frame rails, put in an 8 point cage, tied the floor plate feet to the plated rails and welded 2x4 box sliders to the feet , rails and pinch seam. No more tearing them off and no more sliders parts departing the XJ. ![]() |
#6
Re: Sliders
8 on the frame and 5 on the seam.
#7
Re: Sliders
I put mine on using 9 bolts to the frame rail and four on the anti-lift brackets. I did not bolt to the pinch seam, but put shock pads (cut from hockey pucks) against the floor just inside the pinch seam. These are combination nerf bar/rock sliders which I designed and built. You can see the specs and photos at home.windstream.net/rsolomon/jeep .
Let me know what you think. |
#8
Re: Sliders
Re: Sliders
Re: Sliders
When I built my rails I used 6 1/4-20 through 1x1x1/8 tube to the pinch seam. Then I used 6 (2 per plate on the 3 legs back to the "frame") 3/8" self tapping flange hex head cap screws that I bought from McMaster Carr. Has worked just fine. The self tappers did have some trouble tapping into the "frame" and I did actually use a tap to help get them started in a couple spots but overall fairly easy.
These are old, but: ![]() ![]() |
Thread Tools | |
Display Modes | |
T&T sliders | Matt98XJ | Modified Tech Discussion | 1 | April 21st, 2006 19:33 |
sliders | NC4X4boy | Modified Tech Discussion | 4 | April 14th, 2006 16:48 |
New xj sliders. | mack | Modified Tech Discussion | 30 | March 22nd, 2006 00:40 |
Sliders | whoozey1953 | Modified Tech Discussion | 18 | April 14th, 2004 14:43 |
Ron S's roof sliders | Pat | Modified Tech Discussion | 15 | December 23rd, 2003 14:27 |
