OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
Jeep not starting HELP FAST!!!
Okay, the other night i pulled over to the side of the road and my jeep just cut off within 20 seconds. So i jumped it, kept my foot on the gas and made it home. I put a new alternator in, thinking that would fix the problem, the amps were reading zero on the guage. They now read right. I put a friends battery in. I figured mine would be dead by now. Now, just like before, as soon as I let off the gas, the jeep dies. What could it be. I cant figure it out. I need help as soon as possible. By the way, this is a 1999 jeep cherokee. Thanks...
#2
Re: Jeep not starting HELP FAST!!!
Just to clarify, the jeep cuts off as soon as i let off the gas, it doesn't sputter so it doesnt seem to be a fuel problem. Also this is a 4.0 litre.
#3
does the engine shut down or the whole truck ? check the ground cable ?
#4
Just the engine. I have power to the rest of the jeep such as radio, lights, etc... Everything seems to be grounded right though. I'll check that again tomorrow. Any other suggestions?
#5
Also, when i turn the key the jeep will either not turn over and just click or it will turn over really slowly and not fire until i give it a little bit of gas. I need help as soon as possible. I dont really have any other form of transportation right now.
#6
starter
#7
I can get it to start though by jumping it, but if i let off the throttle once it is started the jeep dies. I don't think thats would be the starter failing.
#8
#9
check both cables from the batterie , i had a similar problem , would click and not start died sometimes , turned out to be the ground cable had lots of corrosion and not enough amps were getting through
#10
I'll double check that ground, and the ACM. Any other suggestions?
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
"new" 87 cherokee 4.0 starting issue | scase86 | OEM Tech Discussion | 9 | May 18th, 2005 07:46 |
Jeep has been starting poor lately, what and where? | VDoubleUVR6 | OEM Tech Discussion | 5 | May 13th, 2005 19:08 |
Jeep not starting......help please | muddy92xj | OEM Tech Discussion | 2 | May 7th, 2005 15:16 |
Jeep starting trouble please help | TBLimited | OEM Tech Discussion | 7 | April 28th, 2005 09:06 |
Ideas for my JEEP room | DrMoab | Non-Tech / Off Topic | 37 | October 16th, 2004 19:15 |
