Modified Tech Discussion Forum for Tech related discussion for Modified XJ's and MJ's. |
Thread Tools | Display Modes |
aluminum heater core and brass/copper radiator
What coolant should I use? I am about to replace my aluminum radiator with a copper brass one but my heater core is still aluminum. What coolant should i use?
#2
Re: aluminum heater core and brass/copper radiator
What are trying to imply, you've also got a aluminum wp and t-stat housing bolted to a steel block/head?
#3
Any coolant.
You're overthinking it.
I'm not a complete idiot - there are parts missing. |
#4
Been using Prestone extended life coolant for decades in a Triumph car, aluminum and copper parts, along with cast iron. change it out every 3 or 4 years, even though the bottle says it is good for 5 years. No problems also run same in an old porsche with a cast iron Buick 231, and copper radiator, aluminum thermostate housing.
#5
Thanks for the replies
#6
This is the third time this week I've been accused of overthinking stuff. Lol I can't help but loce researching stuff.
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Copper/brass heater core for less than $400? | Ben824 | OEM Tech Discussion | 46 | January 11th, 2019 14:43 |
Copper/brass heater coil? | RCP Phx | OEM Tech Discussion | 4 | January 5th, 2018 09:29 |
Renix Radiator :copper/aluminum? | GregGA | OEM Tech Discussion | 7 | January 9th, 2014 22:36 |
Heater Core Replaced - aluminum unit | spitfyre | OEM Tech Discussion | 14 | November 22nd, 2011 13:06 |
Which aluminum 3 core radiator should I go with? | dieselenthusiast | OEM Tech Discussion | 9 | March 11th, 2011 11:20 |
