Old April 28th, 2011, 19:24
DezertTitan DezertTitan is offline
Rats nest!
Ok so the damn thing decided that it didn't want to start the last time I drove it to the smog shop. Battery is good, starter spins, infact I had O'reily's swap out the thing under warranty! I pulled the battery & the (I think!!??) starter relay. Gonna test that. Lights all work, fuel pump primes, etc, but turning the key to "start" gets no results.
Anyways, theres a damn rats nest of wires! What the crap!! This the way every body elses' jeep looks? There were 4 wires connected to the bolt. A small green wire connected to the center stub & then the two push on connects on the bottom 2 stubs.
Also what's with those black chunks of rubber on the wires? That the "fusable link" I've read about? How do you check to see if that's any good (short of it being destroyed completely).
One last thing, the pic w the wire I'm holding - connects in @ 3 to that green wire, which also stems off @ the flat bolt-connector (ya I know, my terminology sucks. Sorry). The push-on connecting in my hands wasnt connected to a damn thing, just wrapped up in itself. Any idea what it's for? Thanks for reading this sorry that I can't be more descriptive.
http://i22.photobucket.com/albums/b3...p/6e4c334f.jpg
http://i22.photobucket.com/albums/b3...p/da44d3c4.jpg
Old April 28th, 2011, 22:04
Re: Rats nest!
Posted that with tapatalk via my iPhone. Looks like the pics didn't turn out quite right. Lame. Operator error. I'll fix it shortly.
Anyways, turns out I had a bad connection... Only thing I can think of. I cleaned the bottom two slip on terminals with a wire brush because I noticed the continuity test with my multimeter was real sketchy. Not sure if that did the trick or if it was just a loose wire. Jeep fired up tho!
Odd the edit button is not on my other post. I'll just throw the pics on the bottom of this one.
So Cal desert rats scottmcneal SoCal Chapter 16744 December 6th, 2015 15:19
Hey desert rats of palm spings scottmcneal SoCal Chapter 37 March 18th, 2012 08:06
Rats with Hooves: zluster Colorado Chapter 31 August 14th, 2009 22:49
hey oldman smithers, socal rats 76ANTHONY SoCal Chapter 44 July 2nd, 2009 18:22
RATS AGAIN goodburbon Red River Chapter 7 June 18th, 2008 12:34
