Old May 8th, 2019, 11:53
RCP Phx RCP Phx is offline
Re: 241OR swap in a 2000XJ
I know your going to love it but, and I hate to even tell you this but they have a 2LO kit for it.
Old May 8th, 2019, 19:35
Heavyopp Heavyopp is offline
That’s a good lookin Jeep — what is your tire size/ lift height?
Old May 8th, 2019, 20:38
bajabronco bajabronco is offline
37x12.5R17 BFG Krawlers with around 5.5" of lift, RE 4.5" coils and 1" spacer and Notch Customs flairs.The rear has some old, soft ass Zone 3" springs, a shackle relocation bracket and a 5" boomerang shackle. I am installing a longer boomerang shackle and moving it farther back in the relocation bracket.
Old May 11th, 2019, 04:55
srb531 srb531 is offline
37's thats big, have you changed axles ?
Old May 11th, 2019, 11:20
srb531 - I am running a G2 high pinion Dana 44 with RCV axles in the front and a Ford 8.8 in the rear.
Old May 11th, 2019, 13:53
i like it...........
Old May 12th, 2019, 16:16
banderso banderso is offline
Originally Posted by bajabronco View Post
I initially tried to use a floor jack but that didn't work well, so I found the easiest way to do it is to lay under the truck with the tcase on my chest and simply bench press it up. I had a buddy with me and he simply helped guide it in.
Any tips beyond this? Bench pressing this thing and and trying to wiggle it into place solo isn't going so well. I can get it up and just barely started, but it won't slide into place.
I'm thinking of grabbing a harbor freight transmission jack. Seems like that would make it pretty easy, right?
Old May 12th, 2019, 16:49
Rockwood Rockwood is offline
I have one and itís very much worth it. Used to bench press drivetrain parts all the time, but I like not bashing my hands on everything.
Old May 12th, 2019, 17:00
Are you sure you have the correct spline count/length. I did mine by hand and slid directly in. Make sure you have everything in neutral.
Old May 12th, 2019, 17:13
Good question, but I'm pretty sure it's the right spline count. I do have a '91 so I wondered about that. I counted the splines on the case that came out and got 23 both times, so I think I'm good.
Splines engage juuust enough that if the case is in gear and the trans is in neutral, the trans output spins by turning a tcase yoke. Definitely wondering if I'm missing something stupid like that though. Sure seems like the amount of grunting and wiggling I've done should have gotten the job done.
Old May 13th, 2019, 12:35
Banderso, when I did mine, I literally pressed it up, my buddy told me to bring it down a little bit to line it up, and it slid right on. - No problem what so ever. I guess I was lucky! My XJ is a 2000 with a AW4. I had my Tranny in gear and my Tcase in 2WD when I slid it in.
Old May 13th, 2019, 16:34
Thanks for all the input. I found my issue - one of the studs is bent and that's why it's not lining up with the trans. I just need to double nut it, back it out, replace with one out of the 231, and I should be good to go.
Old May 30th, 2019, 05:25
puredrive puredrive is offline
Nice Jeep.
Is that an aftermarket cage/rack?
Old May 30th, 2019, 10:08
It is the XOFab Hybrid Cage for the XJ . http://shop-xo-fab-com.3dcartstores....t-_p_1759.html
After installing the cage, and how much effort it took to make everything fit correctly, it would probably have cost the same just to have a custom cage made, and it would have probably fit better. The one bar that comes in the kit for the harnesses that is suppose to go behind the B pillar bars does not work. They just give you a straight piece of tubing, which doesn't fit with the seats. I still need to bend up a harness bar and a cross brace for the B pillar. I also added the ability to remove my C pillar cross brace when I need to toss more stuff in the back when I am not wheeling. Over all I am happy how it turned out.
JK vs TJ 241OR?? Hemenechi Modified Tech Discussion 10 August 3rd, 2018 16:13
241OR swap question mcguyver_xj Modified Tech Discussion 13 March 25th, 2012 13:24
241OR swap help Unibuddy Modified Tech Discussion 11 February 2nd, 2012 03:57
241or swap bmfm64 Modified Tech Discussion 6 January 3rd, 2010 08:08
Mid-241or swap billyjp2 Modified Tech Discussion 1 September 12th, 2008 18:44
