Old April 28th, 2019, 22:43
chasdb's Avatar
chasdb chasdb is offline
NAXJA Member 3643
Re: Project Unicorn - a light duty trail rig
Well, the good news is GLOM is fine.
I'm happy to hear it lives, I want to see you put some miles on this one!
'00XJ Mall Krawler Edition Russ Pottenger 4.7Stroker,241OR, Rock Krawler aluminum 3 link, D44hp Yukon air zip, D44 35 spline axles locked by RWKHaus. Stiffners, and brackets by Ruffstuff. High steer-Parts Mike. T&J, fenders+ cage. Bilstein 7100, 35 KM2, OMF Beadlocks, PAC coils, Deaver G9leafs, BrownDog mounts, Currie antirock, PSC hydro
my build
Old April 29th, 2019, 22:20
GSequoia's Avatar
GSequoia GSequoia is offline
Everyone says I'm a jerk.
I'm maybe a little less bothered by engine failure than you are.
Plus. You know. You're used to it.
Prior President & Prior SoCal Chapter President
Originally Posted by Bent
Us normal people...
Old April 30th, 2019, 08:16
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
you may not know this, but you're kind of a jerk.
Old April 30th, 2019, 08:23
sidewaysstarion's Avatar
sidewaysstarion sidewaysstarion is offline
Coffee Drinker
A jerk that needs to fix his jeeps.
Originally Posted by cracker
I seem to have run out of self tapping washers
99 4.0/AW4/231, with a few basic bolt ons.
Click here to support
Old April 30th, 2019, 11:14
GSequoia's Avatar
I need to stay in L.A. long enough to do that.
Us normal people...
Old April 30th, 2019, 12:28
Anak's Avatar
Anak Anak is offline
Stranger
I will grant that it helps to be home.
My XJ is my daily driver, if I am home. Just yesterday I noticed I was down to about a quarter tank so I stopped and fueled it up. Pulled out my fuel log and saw that the last time I fueled it up was in mid-January.
Dang.
I am ready to be done with this particular season of life.
Baby it's cold outside.
Old May 12th, 2019, 19:05
cal's Avatar
cal cal is offline
Not a whole ton to update here.
When I did the genrite tank, my fill hose and vent were in really lousy condition. I changed those out Friday. Only took one picture of everything on the ground, the old hoses were filthy enough that I never wanted to touch my phone.
Gates 24710 1.5" fill hose and a 5/8" fuel hose for the vent.
Saturday I pulled the dash and changed out the heater core. Kind of a PITA job but not as bad as I was expecting.
Turned out I didn't quite have enough hands to get everything back in place with the dash in the way, Itscheesy came by to help me slam it all back together and then took it for a test drive.
I think he enjoyed it.
Today I filled the tank all the way for the first time since installing it. It takes ~9 gallons after the fuel gauge pegs on full. Did 180 miles up to Tholke's and back, 80 mph the whole way there and 65 all the way back, averaging 18.9 mpg. Not terrible, but I think a new torque converter may improve it some.
Old June 4th, 2019, 14:16
cal's Avatar
cal cal is offline
Well, I'm still getting some pinging. Talked it over with Russ and we've decided to lower the compression ratio a bit.
Before pulling the engine for new pistons, we're going to try making adjustments to this one. Currently we're at 11.4:1 with .026" quench on a .043 head gasket. Going to pull it and try a .060 head gasket for 10.93:1 and .044 quench.
Also going to try out some new lifters while its apart.
Started out by calling up SC_Redneck and having him catch a flight out to visit.
We yanked the head off this engine like we're pull starting a lawnmower.
Noticed a couple of things here. Kind of an excess of carbon buildup for an engine with ~1K miles on it. And way too much JCR Handicorn.
This does not excite me. More on it later.
.... Project Unicorn you say?
The exhaust valves are pretty clean but the intake are just caked.
Went ahead and pulled the Comp lifters out (right) and replaced them with Johnson lifters (left). I've had some lifter noise since day 1, and it is becoming more common with the Comp lifters. Russ is looking at these as a replacement.
New Cometic .060 gasket.
Must be built for a TJ. Slight interference with the AC bracket, we just trimmed the gasket.
That's a lot of gasket. Would be an issue if if the pistons werent .016 out of the hole, but it may be a problem solver here. Time will tell.
The supervisor approves?
Head back on, rockers checked for proper preload (which amazingly was just fine).
5 spark plugs looked healthy, but Cylinder 6 has clearly been detonating.
Valve cover back on, and waiting for the new manifold gasket to arrive today.
We're pretty certain at this point the crappy baffles in the Crown valve cover are letting the engine suck oil, which is burning poorly and contributing to pinging. I'll be adding a catch can to the PCV and probably go back to a stock valve cover.
Old June 4th, 2019, 19:28
JohnX's Avatar
JohnX JohnX is offline
Sarge <3 Ben
I'm curious to see the outcome from the compression drop, my experience has been worse pinging because of quench increase....but my experience was not on a jeep....so??
Also, maybe this has been covered....but have you flowed your injectors? I have a fancy machine for it if you want me to check them out?
The MAC-10 submachine gun was practically designed for housewives.
Old June 5th, 2019, 03:56
Ghost's Avatar
Ghost Ghost is offline
Member Number 257
Have not seen SC Redkneck in a while....
"...I need to wheel to be rejuvenated to fix things to wheel. It's a vicious cycle, but I love it."
Rick Pewe Ed: Petersons 4 Wheel and Off Road
member since 3/05/2001
Old June 5th, 2019, 06:17
cal's Avatar
cal cal is offline
As a general rule, you are absolutely right. Russ believes that because this one was so tight to begin with, that we may get away with it. Our final quench will still be exactly half of what stock is.
I have not. They are brand new 30 pound injectors from Five-O motorsports, so I didn't really feel the need, but I may take you up on that.
Old June 5th, 2019, 06:18
cal's Avatar
cal cal is offline
Yeah he's Tennessee Redneck now, and its hard to get him out of his backwater village.
Old June 8th, 2019, 10:00
denverd1 denverd1 is offline
Ton of buildup on those pistons. Any idea what's causing it?
Old June 8th, 2019, 12:29
lazyxj's Avatar
lazyxj lazyxj is online now
NAXJA Member #1310
Are the 30-lb injectors too rich. Sure looks the way.
So much for custom tuning.
I'm running 27-lb injectors in my Russ stroker, with a lower compression ratio.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old June 9th, 2019, 09:31
cal's Avatar
cal cal is offline
Don't knock the custom tuning. The name of the game that day was "try and tune out the pinging" and I documented it as such.
It was still pinging under some scenarios, which is why we're now trying a thicker head gasket.
A lot of theories on the buildup. Obvs it is rich under load (we knew that), and there are some interesting theories that overtight quench may be extinguishing burn in the quench zone (not sure I buy that one, russ sure doesn't).
I cleaned up as much of the buildup as I could, gonna put some miles on it and do a seafoam, and if I don't see immediate pinging, schedule another tuning session to see if we can dial it back without more pinging.
If it still pings after that, probably have to have a new set of pistons knocked up dropping the compression a bit more. Our original goal was 11:1, the 11.4 was an accident (I re-used the race car crank and didn't consider it was offset ground). It will be interesting to see what happens, about to go out for the first test drive now.
New Project 89 XJ Unicorn zachxj01 North Atlantic Chapter 9 May 26th, 2016 16:39
Anyone use OME LIGHT DUTY leafs? djlarroc Modified Tech Discussion 19 August 10th, 2013 18:39
Project:Unicorn SAMSET Midwest Chapter 27 September 28th, 2012 10:58
WTB light duty truck tires XJwheelman NAC Classifieds 0 June 5th, 2011 14:41
Some light duty mods for a camping XJ terryd Modified Tech Discussion 10 January 11th, 2008 16:50
