nope. thick gears can be used on a stock carrier such as a 3.55 carrier. "thin" gears are used on a carrier for higher gears( or lower i always mix that up) so basically if you want to use your stock carrier buy thick gears and if you buy a new carrier or a full case locker get the thin gears.
