Old March 18th, 2020, 06:48
bjorhei36 bjorhei36 is offline
Clunking when turning left and going over bumps
Hi! I have a bad case of clunk noise coming from what sounds like the front end passenger side. It only appears when Im turning left or going over small sharp bumps. No clunking when turning right.
Also, the noise sounds really loud inside the vehicle, but can barely be noticed when standing outside. I can not hear the noise when I try to provoke it in my garage, it only appears when driving.
I have changed several components at the front end, which are:
- Ball joints (all four at the front)
- Front axle U joints
- Track bar
- Tie rod ends and drag link
- Steering stabilizer
- Sway bar links and bushing
From visual inspection the control arms, the shocks and the hub assembly looks fine. Im really getting frustrated here, so all help would be greatly appreciated.
Thank you.
Old March 18th, 2020, 07:10
RCP Phx RCP Phx is offline
Re: Clunking when turning left and going over bumps
The most common would be control or trackbar mounts.
Old March 18th, 2020, 17:02
xjnp242 xjnp242 is offline
After all you replaced, i'd 2nd control arm bushings.
Don't overlook a bad shock bottoming out.
Make sure the track bar's mounting bolt holes are not worn oblong.
Old March 21st, 2020, 05:50
cruiser54's Avatar
cruiser54 cruiser54 is offline
Make sure the track bar mounting bracket bolts are tight. Don't just look at em. Put a wrench or socket on them.
Old March 21st, 2020, 13:40
I have replaced the track bar, its tight. I also had the one of the LCAs off today to look at the bushing, and the bushing was in good condition by the way.
Old March 21st, 2020, 14:13
cruiser54's Avatar
BRACKET to FRAME bolts.
Old March 21st, 2020, 14:16
Sorry, my bad. Yeah, theyre tight too.
Old March 21st, 2020, 14:18
cruiser54's Avatar
You've put a tool on them and verified?
They were undertorqued from the factory........
Old March 22nd, 2020, 03:23
Yes I have, they are tight.
Old March 22nd, 2020, 16:53
8Mud's Avatar
8Mud 8Mud is offline
Most anytime I get that clunk clunk when turning into a driveway it has something to do with the ball joints.
Jack up the front axle until the tire is off the ground, use a brick or something as a fulcrum pry the tire up with a long bar or piece of 2X4. Look closely at the ball joints top and bottom. New doesn't necessarily mean good. Or it is possible the ball joint bottom is moving in the knuckle, sometimes the diameter of the ball joint is too small and it can move in the knuckle or the hole in the knuckle is rusted or wallowed out and too big.
Old March 22nd, 2020, 17:00
8Mud's Avatar
Also, check the steering box bolts I've had them come loose. Also have a look and see how much up and down play you have in the pitman arm, might as well tighten the pitman arm bolt while your down there.
What year XJ?
Old March 22nd, 2020, 17:03
8Mud's Avatar
What size tires are you running, your tire may be contacting the control arm.
Old March 25th, 2020, 12:36
Checked the ball joints again just to make sure, theyre not it. I also run small wheels, they have not been making contact with the LCA.
Checked the pitman arm bolt, tight as well.
Old March 26th, 2020, 06:55
8Mud's Avatar
Try pushing and pulling hard on your valve cover from the side. A quick check for motor mounts.
I put my feet on the passenger's side of my transfer case and bounce a little to check the rear trans/transfer mount.
Shock bushings?
Is it possible the exhaust is banging your cross member, grab he exhaust near the cross member and push up and pull down hard. Pretty common for the exhaust to contact there.
If it isn't obvious it almost has to be exotic.
Did you look at the steering box mounting bolts?
Can you feel the clunk through the steering wheel? Or do you just hear it?
Not likely but is it possible your rear axles U-bots have stretched or come loose?
It may sound like it is coming from the front right, but the reality is it could be anywhere. I've been fooled before, sound travels through the drivetrain you can't trust your ears for location, especially from inside the vehicle.
Another oddball your front brake pads lose on the rails, not loud but they can clunk.
Little clunking while turning at full lock.. Tony_SS OEM Tech Discussion 5 October 26th, 2013 18:53
front end clunking when turning 2001JeepXJNS OEM Tech Discussion 7 May 10th, 2013 06:13
Clunking when I hit bumps. Going crazy. Tried just about everything. RoyalXJ Modified Tech Discussion 20 February 4th, 2010 16:12
strange wheel wobble hop when going over speed bumps & turning slow XJ Buddy OEM Tech Discussion 8 September 3rd, 2009 21:45
Strange clunking noise when going over bumps. newjeepowner OEM Tech Discussion 12 July 21st, 2006 19:41
