outlander
- Columbus,Ohio
Renix 4.0
I was out in the garage messing around with my engine scanner and noticed something strange.
With engine off key on i was watching the tps signal while i was pushing the gas pedal.
At the same time i had the o2 circuit pulled up on split screen and noticed that when i pushed the gas the o2 feed would go up a few 10ths of a volt....
Weird right?
Is this something normal or should i start digging into the harness and see if ive got a short between the two circuits?
Weird right?
