Old October 11th, 2018, 21:53
Wiser's Avatar
Wiser Wiser is offline
Question Np242 shifters
Is there a difference in transfer case shifters between years 84-96 and 97-01? I have a 98xj with a 242 installed in it but the shift gate in it now is for a 231. Iíd like to change it out so I can shift it into 4low. I found a 242 shift gate out of a 1990 model on eBay. Was wondering if this shift gate would work in a late model xj? Thanks.
Old October 12th, 2018, 06:01
cruiser54's Avatar
cruiser54 cruiser54 is offline
Re: Np242 shifters
I don't think they're different. How much on ebay?
Old October 12th, 2018, 06:07
Wiser's Avatar
Re: Np242 shifters
Cool, itís $40 shipped or best offer. Iíve also heard I could grind the shift gate?
Old October 12th, 2018, 06:26
cruiser54's Avatar
Re: Np242 shifters
PM me your email address and I'll send you a side by side photo.
Old October 12th, 2018, 07:35
Wiser's Avatar
Re: Np242 shifters
PM sent.
Old October 12th, 2018, 08:10
RCP Phx RCP Phx is offline
Re: Np242 shifters
I can't speak for my 2k's, but on my 95 I didn't change anything but the bezel going from a 242 to a 241OR.
Old October 12th, 2018, 09:29
Wiser's Avatar
Re: Np242 shifters
Interesting. So you should have extra throw in your shifter since you went from full time to a partime only transfer case? Basically my XJ doesn’t have the extra travel on the transfer case shifter to shift the 242 into low range.
Old October 12th, 2018, 12:32
lawsoncl lawsoncl is offline
Re: Np242 shifters
Can you PM me as well? I've got a 1993 NP-242j sitting on the bench to replace an 1989 NP-231j. Just have to decide if I want to rebuild tit first, and whether it needs a chain (what's the spec for chain stretch?)
Old October 12th, 2018, 21:41
Re: Np242 shifters
Originally Posted by Wiser View Post
Interesting. So you should have extra throw in your shifter since you went from full time to a partime only transfer case? Basically my XJ doesnít have the extra travel on the transfer case shifter to shift the 242 into low range.
Have you checked all your linkage bushings? Have you tried adjusting it? How is your transmission mount?
Old October 13th, 2018, 06:52
cruiser54's Avatar
Re: Np242 shifters
Old October 13th, 2018, 09:05
Wiser's Avatar
Re: Np242 shifters
Havenít yet, Iíll check them out today when the rain stops
AW4 shifters and more R.DesJardin Vendor Advertisements 0 May 3rd, 2016 19:37
aw4 shifters Greg1993 Modified Tech Discussion 1 November 1st, 2011 20:42
2 Spd Stak box--which shifters???? gatmetalxj Modified Tech Discussion 13 January 2nd, 2007 07:00
shifters? always_eating_mud Modified Tech Discussion 7 October 18th, 2006 21:41
Aftermarket Shifters for ax-15 Rem870XJ Modified Tech Discussion 1 February 1st, 2005 19:15
