OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
Bad CPS= injectors not pulsing?
I have check my FSM and searched without luck.
After replacing the rod bearings my XJ won't start (2K). The only electrical item I touched was the cam position sensor and I have quadruple checked it (has 5v, and I reset it to FSM specs) I have checked and there is no spark and the injectors are not pulsing. I hooked up my injector tester and they(injectors) were fine and there is plenty of fuel pressure. Eveything I have checked points to the Crank sensor but it makes no mention of it affecting the injectors. TIA for the help. Nathan |
#2
Re: Bad CPS= injectors not pulsing?
Only a couple of things will cause no spark. A camshaft position sensor is not one of them. The crankshaft position sensor can cause the problem. Double check all fuses. Plug and unplug the CPS connector. Your problem is best troubleshot as a no spark problem, not an injector problem.
#3
Thanks for reply.
I have checked everything several times. I figured the CPS was toast, it is the original 95k unit and has seen some abuse. The fuses were a treat to check (hence my post listing all the fuse locations/functions). |
Thread Tools | |
Display Modes | |
Replacing injectors and? regulator | 3XJFamily | OEM Tech Discussion | 1 | March 9th, 2005 11:42 |
Front axle Ujoints bad??? | Twisted Copper | Modified Tech Discussion | 9 | January 27th, 2005 19:11 |
Drivability with larger injectors | JBrobeck | Modified Tech Discussion | 11 | December 1st, 2003 13:15 |
bad u-joint??? | skog | OEM Tech Discussion | 1 | April 15th, 2003 11:19 |
TPS gone bad | FatXJ | OEM Tech Discussion | 4 | March 30th, 2003 14:51 |
