sumofatguy
- alberta
Hi everybody. I have a 2000 XJ which started showing the classic symptoms of a bad tps/wet tps right after I sprayed down the engine; sputtering, stalling, bad idling etc. It threw the p0122 and p0123 engine codes.
Today, I bought and installed a new TPS and cleared the codes and disconnected the battery to reset the computer, and the same codes came back up and the jeep continued to sputter/stall. According to another post i found:
the middle orange/dark blue wire is the TPS signal wire back to the computer. When I test this wire, I constantly get 12V, regardless of throttle position. pin 3 reads 5.18V and pin 1 has a decent ground.
Any suggestions what I could do here? do I have a short somewhere on pin 2? How can I fix this??
muchly appreciated
Throttle Position Sensor (TPS):
1 | Brown/Yellow | Sensor Return (-)
2 | Orange/Dark Blue | Throttle Position Sensor signal
3 | Orange | 5V Reference (+)
muchly appreciated
