Old August 29th, 2019, 15:48
Unclewolverine Unclewolverine is offline
Newer aw4 in older jeep
Im a rural carrier and im looking at a 94 rhd with a bad trans to replace my 01 lhd with many problems, not the least of which is the expected cracked head. The trans is good in the 01 so i looked it up and someone said it can be done by switching some of the stuff in the tail shaft housing. Has anyone done it, and how hard is it?
Old August 29th, 2019, 18:33
RCP Phx RCP Phx is offline
Re: Newer aw4 in older jeep
Read post #1 carefully, it's not that easy.
https://naxja.org/forum/showthread.php?t=1053970
Old August 29th, 2019, 18:54
87renix 87renix is offline
I did this in my renix. I put a 2000 trans in it. It's not hard to make it work, the only real hard part is swapping the speed sensor gear in the trans. Basically you drop the pan and swap the wiring harness from the 94 into the 2001 trans (it's all plug and play but the connectors are different from 94 to 01). Then you would pull the tail housing off and take off the c clips that hold the speed gear in place and put on the one from your 94. Make sure you seal up the tail housing to the trans really well. The 2001 has an input speed sensor that the 94 doesn't, but you can just unplug it and leave the sensor in place. I have had great success with my trans set up this way.
Hopefully that makes sense.
Old August 29th, 2019, 18:55
Oh and make sure to use your 94 output speed sensor.
Old August 29th, 2019, 19:50
lawsoncl lawsoncl is offline
What's wrong with the 94 trans? The AW4 is fairly robust and most problems are the TPS sensor or a bad shift solenoid which are relatively easy fixes.
Old August 29th, 2019, 20:24
It has 190k of mail delivery miles and he said reverse is about gone; which from what i understand is a sure sign its shot. Its in really nice shape though, no rust i can see in the pics. The only annoying thing i see is that the dash is kph, but im pretty sure i can just put in a correct american dash, i think its just plug and play
Old August 30th, 2019, 13:31
Well, I went ahead and bought it the swap seems pretty straightforward so I'm going to go ahead and do it probably start it on Sunday so I can get back to work on Tuesday wish me luck!
Old August 30th, 2019, 14:26
Did you buy it from wireman? :}
https://naxja.org/forum/showthread.php?t=1155596
Old August 30th, 2019, 16:56
Lol, nah this is a 95 limited imported from japan. Its got all the good stuff, 242 t case, antilock brakes, leather in good condition! May be putting some 01 parts up though and eventually selling a rust free but stripped yellow unibody soon!
Old September 3rd, 2019, 21:16
I decided against taking the one out of bumblejeep but i did pick up a 99 aw4 with 140k on it for dirt cheap. Ive got them both on the floor, hopefully will have time to switch everything over tomorrow, thanks 87renix, it does appear to be a much easier swap than i initially figured! Going to reseal the pan with right stuff and pop in a new rms while its up in the air.
Old September 4th, 2019, 21:06
I disassembled the old trans tonight and every single keeper broke on the plugs in the pan :/ thinking now it may be better to do some soldering, definitely dont want to risk the plugs coming undone at any point in the future!
Old September 11th, 2019, 23:00
It works! For anyone considering this swap in the future, if you are confident that you can do the trans install yourself then the modifications to make it work are simple. Just remove the transfer case adapter, swap the 4 prong wheel for the 2 prong out of your old trans by removing the snap ring; use your old adapter (the speed sensor boss is different,) and then since the connectors inside the pan are old and brittle just cut and splice the 3 wires that go into the pan through the grommet near the rear left of the trans. Just leave that unused input sensor there and there you go, 97+ trans in an older (95 in my case) jeep!
older 242 in newer XJ ? Rmart30 OEM Tech Discussion 5 June 21st, 2010 14:41
newer axles in older xj thicky OEM Tech Discussion 9 March 12th, 2010 08:04
newer passenger seat into drivers side in older jeep 95' heep Modified Tech Discussion 9 August 11th, 2009 21:44
newer gas tank in older xj iaml3lue OEM Tech Discussion 3 August 15th, 2008 20:27
Older or newer? SLAYER Non-Tech / Off Topic 12 February 20th, 2007 21:48
