Old December 3rd, 2007, 11:51
89xj4.0 89xj4.0 is offline
Question 89 XJ rearend
89 4 door 4wd. putting an ox locker in the rear but i cant figure out which axle i have. any help or suggestions on finding out would be awesom
Old December 3rd, 2007, 11:52
Begster's Avatar
Begster Begster is offline
Re: 89 XJ rearend
http://www.yuccaman.com/jeep/gear1.html
Old December 3rd, 2007, 12:00
89xj 89xj is offline
Re: 89 XJ rearend
89 is most likely the dana 35c(non c-clip), unless your real lucky, dana 44
Old December 3rd, 2007, 12:28
Re: 89 XJ rearend
HOW DO I TELL THE DIFFERENCE BETWEEN THE 2??
Old December 3rd, 2007, 12:39
PhotographerMike's Avatar
PhotographerMike PhotographerMike is offline
Re: 89 XJ rearend
Slow down.
Take a deep breath.
Go back to the front page.
Try this;
FAQ; Frequently Asked Questions
FAQ topics on common and frequently posted issues.
Old December 3rd, 2007, 12:41
Begster's Avatar
Re: 89 XJ rearend
Or, you can click on the link I first posted, and you will see pictures showing which axle is which...
Old December 3rd, 2007, 13:12
Re: 89 XJ rearend
thanks guys just went and checked out the pumpkin shape and it is a d44. upgrade the shafts while replacing the gears and diff??
Old December 3rd, 2007, 13:25
Begster's Avatar
Re: 89 XJ rearend
Your lucky, D44 is a very strong axle. What size tires will you be runing? Also what kind of wheeling do you see most, mud, rocks, etc?
Old December 3rd, 2007, 13:50
Re: 89 XJ rearend
mud snow ice some rocks. but i tend to drop the hammer alot. 4.0 bored 40 over. .430 lift cam. 33 inch mt/r 4 inch lift
Old December 3rd, 2007, 14:04
87manche's Avatar
87manche 87manche is offline
Re: 89 XJ rearend
buy the new shafts, take the stock ones along as spares.
Old December 3rd, 2007, 14:44
Re: 89 XJ rearend
any certain type or material you would suggest to use or stay away from?
Old December 6th, 2007, 08:07
Re: 89 XJ rearend
are you 100% positive you have the dana44? measure the axle tube diameter. i think the d44 is 3"dia and the d35 is around 2.6"dia
they mostly came in the 87xj with towing package, very rare in an 89xj.
Old December 8th, 2007, 17:30
slcpunk74 slcpunk74 is offline
Re: 89 XJ rearend
If it looks like that non round shape then its a 44. I got my d44 out of an 89 so anything is possible(or likely)
need rearend butthead SEC For Sale / Wanted Forum 6 May 8th, 2007 21:32
8.25 rearend jeeperzcreeperz For Sale: Private Party Only. XJ ITEMS ONLY 2 January 31st, 2007 09:20
Chr 8.25 rearend Brian Carpenter OEM Tech Discussion 14 November 27th, 2006 22:34
New M.O.R.E. 8.8 rearend conversion kit for XJ Elohim1 For Sale: Private Party Only. XJ ITEMS ONLY 1 October 12th, 2006 18:22
AMC 20 Rearend Inisadow Tow Rigs and Trailers 10 November 15th, 2003 02:09
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
