Old May 12th, 2019, 18:06
Lanser1999 Lanser1999 is offline
2001 locker question
So I have a 2001 xj with an auto trans and I believe a 231 transfer case. I’m looking to lock one axle currently but the jeep is driven in Wisconsin winter and freeway driving. I would like a selectable locker but can’t find myself to spend the money on it currently. With that being said I would like to lock the front but need to know a couple things. First off, if I throw a lunch box locker in the front (no disconnect) will it still drive normal in 2WD or will it still drive like it’s locked considering the front driveshaft spins in 2WD? Also, is one brand of lunch box locker superior to the others as far as durability and noise?
Old May 12th, 2019, 19:14
smccollamjr smccollamjr is offline
In normal driving you wonít notice a front autolocker in 2wd. I have an Aussie thatís been in two Jeeps and three axles. Iíve been told the no-slip is the quietest.
Old May 13th, 2019, 04:03
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: 2001 locker question
A PowerTrax No-Slip auto locker in the rear axle of my 2000 XJ behaves almost exactly like the Limited Slip it replaced. Front axle auto-lockers suck in winter on icy/snowy roads. Most members of my local Minnesota 4x4 club remove their front LockRight type Lunchbox Locker for winter daily driving, and re-install it in the spring due to some obnoxious behaviors on pavement during icy/snowy weather.
If you are positive you want a front axle traction device, a TrueTrac Limited Slip would be your best option.
I prefer a rear axle traction device for Minnesota winter daily driving, and for 4x4 trips to the North Woods and Moab. This provides lots of predicable traction and almost no odd behaviors form either the locker, or the Jeep.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Old May 13th, 2019, 11:50
denverd1 denverd1 is offline
Originally Posted by Tim_MN View Post
A PowerTrax No-Slip auto locker in the rear axle of my 2000 XJ behaves almost exactly like the Limited Slip it replaced. The front axle auto-lockers suck in winter on icy/snowy roads. Most members of my local Minnesota 4x4 club remove their front LockRight type Lunchbox Locker for winter daily driving, and re-install it in the spring due to some obnoxious behaviors on pavement during icy/snowy weather.
this or drop the coin on selectable front.
Old May 13th, 2019, 14:47
Tim_MN's Avatar
The beauty of a lunchbox type locker is the reasonable price, and that you can yank it out and go back to an open differential in a few hours if you don't like it. They are an excellent way to dip your toes in the water for lockers before you commit big money to a selectable locker.
Old May 13th, 2019, 15:01
TRCM's Avatar
TRCM TRCM is offline
true, but after seeing what it can do, most don't.................
Old May 13th, 2019, 17:45
Post Re: 2001 locker question
Thanks guys. Thinking Iíll go with just a rear for now and get a selectable front eventually. Need to get the IRO long arms before I get a selectable locker.
Old May 15th, 2019, 07:48
i'm rolling lunchboxes in both ends of mine! agree, easy to install/replace if you don't like it.
just test it and get familiar with it once the white stuff shows up.
Old May 15th, 2019, 11:42
devildog0's Avatar
devildog0 devildog0 is offline
I ran LockRights in two prior Jeeps and went with a No-Slip in my current XJ. Love it. Invisible unless at full lock and even then you won't hear it if you have the radio on.
Do some searching around. I don't live in an area that gets a lot of snow/ice but I've found opinions on the subject of a front locker in snow/ice go both ways. Some guys love them and run them year round others don't like them in snow/ice. On the plus side if you don't like it you can replace it with the spider gears for winter use in about a hour or two if you have a Lubelocker gasket (highly recommended)
1995 XJ Country/4.0L/AW4/231/UpCountry Suspension
2004 Suzuki DL650 VStrom/1978 Suzuki GS1000E/2003 Yamaha TW200
1982 Suzuki GS850G (barnfind project)
Old May 15th, 2019, 13:18
VAhasnoWAVES VAhasnoWAVES is offline
i never had an issue in cold weather conditions. under too much throttle or taking a turn too fast and/or sharp the vehicle will want to under steer and both tires break traction and dont provide any steering input. its pretty simple... slow down or coast around the turn. if the roads are so bad that you need 4wd then you shouldnt really be in a hurry to get anywhere anyways.
i always suggest front lunchbox locker. id rather adjust my driving for the 1% of the time that the weather is bad than the 99% of the time that i drive on the street. chirping tires and "clickity-bang" all the time gets old.
Old May 15th, 2019, 16:07
Tim_MN's Avatar
Front Auto-Locker behavior may depend on the brand and model installed. My LockRight D30 locker hates winter weather. On snowy/icy roads It doesn't like to unlock in 4x4, causing under steer and both front tires to break traction. In 2wd when one front tires is on ice/snow and the other tire has more traction and the brakes are applied, it tries to engage, but only partially. I would never let an inexperienced driver use 4wheel drive with a front auto locker equipped 4x4 on snowy, icy pavement due to the handling quirks the auto locker has.
My rear PowerTrax No-Slip auto locker has no clicking or chirping (unless you nail the throttle) and goes bang maybe once a year.
If a person is only going to install only one locker for winter daily driving I recommend a rear locker. If a person is going to install a traction device in the front axle for winter daily driving, I recommend TrueTrac Limited Slip, or a selectable locker. YMMV.
Old May 16th, 2019, 05:58
interesting rebuttal. my only experience with a front lunchbox was with an aussie. of course everyones experience and results may vary. its up to the OP to choose what is tolerable.
i will say... that when i installed a lunchbox in the rear, i destroyed it in short order. i dont think a lunchbox in the rear is up for the driveline shock associated with a manual trans.
Old May 19th, 2019, 09:12
Soapy1 Soapy1 is offline
I run Spartan lunch box on both axles. I can hear the front more than the rear. They both click when turning but nothing bad.
2001 drivetrain question gray_penguin OEM Tech Discussion 5 July 25th, 2015 05:42
2001 XJ Dana 30 Question? Bville99gt Modified Tech Discussion 9 November 3rd, 2008 06:08
2001 Question s7tech SoCal Chapter 1 May 4th, 2008 12:56
newb question 2001 XJ evoIX OEM Tech Discussion 2 June 7th, 2006 09:09
2001 w/ABS need a L/S or locker..... BMWNUTw/XJ OEM Tech Discussion 6 July 24th, 2004 18:05
