Modified Tech Discussion Forum for Tech related discussion for Modified XJ's and MJ's. |
Thread Tools | Display Modes |
renix air filter
What are you using?Do you notice any performance gains or increased mileage?Trying to figure out if a $40-50 filter is worth the money....I will be keeping the stock air box indefinately becuase I have a cowl snorkle rigged to it.....
thanks!! Last edited by outlander; June 23rd, 2007 at 17:46. |
#2
Re: renix air filter
JP Mag and others have tested the replacement filters with the stock air box and found very little gain. I went with the K&N system and there was quite a bost in performance. Save your money if you are going to use the stocl air box.
#3
Save your pennies and stroke your engine later - it's probably the best mod going; in terms of power/dollar, overall reliability, and useful power.
Bored throttle bodies (according to reports from the field) make the trottle response a little quicker, but that's about it. The OEM throttle body (even on RENIX...) will flow enough to keep the engine fed - even a stroker. Larger injectors are only really useful when you've increased the engine's basic displacement (bored/stroked,) forced induction is a lot of work (especially turbochargers!) and getting happy with giggle juice can make you end up eating engines like popcorn. Just hold onto the $50 you've got, and add to it as you go. |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Renix oil filter adapter turned 90 degrees | Ecomike | OEM Tech Discussion | 12 | February 10th, 2007 15:09 |
Renix era Oil filter | Wayne Sihler | OEM Tech Discussion | 2 | April 22nd, 2006 14:00 |
anyone in cali swap a HO in a renix yr and pass smog like its a renix? | RWKHausSupply | Modified Tech Discussion | 8 | January 30th, 2006 14:55 |
Renix to HO oil Filter mount | TUFFXJ | Modified Tech Discussion | 4 | March 24th, 2005 15:00 |
oil filter for renix | itzak | OEM Tech Discussion | 1 | January 22nd, 2004 15:04 |
