Old February 13th, 2018, 08:03
freedy freedy is offline
Fitting 35's
I just graduated to 35" MT/Rs from 33" Swamper SSRs and looking for tips on what people have done to stuff them into the wheel wells as much as possible. I've done all the usual stuff and then some to get the 33s to stuff in really well. With the 35s I see my first constraint is the inside rear of the wheel well when turning. In the rears it looks like the outside rear of the wheel well at the bottom of the flare. I've got 5" or maybe a tad more of lift and prefer not to go higher unless there's a good reason.
Old February 16th, 2018, 08:46
denverd1's Avatar
denverd1 denverd1 is offline
Re: Fitting 35's
push axle forward 1.5"
Old February 16th, 2018, 10:49
DutchVDub's Avatar
DutchVDub DutchVDub is offline
Re: Fitting 35's
This is my second XJ running 35's on a 4.5" lift. On both of them I used the factory flare up front as a guide for my plasma cutter to trim the fender out. That big seam that runs down the backside of the front wheel well I folded over with a rather larger hammer. Out back I just removed the stock flares and used a rather large hammer to fold over the edge of the fender that it bolts to. Basically like most people do except that I don't make slices first. Its actually pretty easy to fold over with a mini sledge. I keep going around and massage the entire wheel well to be a bit bigger, just watch the door gap on the rear door.
After that I just bump stop accordingly.
Americans can sleep at night because US Soldiers stand ready to fight
Old February 16th, 2018, 16:15
OPXJ2010's Avatar
OPXJ2010 OPXJ2010 is offline
Re: Fitting 35's
Nice XJ! Off topic, is that a custom bumper?
Old February 16th, 2018, 17:35
DutchVDub's Avatar
Re: Fitting 35's
Thanks, and yes. I built it myself with help from a friend.
fitting 33s? shotstopper Modified Tech Discussion 23 August 8th, 2007 17:37
fitting 33's...?? N20Jeep Modified Tech Discussion 6 May 26th, 2007 21:57
Fitting 33's Red98 Modified Tech Discussion 14 August 23rd, 2006 23:04
Fitting M.I.T. SYE kit xjdavid1 Modified Tech Discussion 5 January 26th, 2006 02:14
fitting 33's hlfnavyas Modified Tech Discussion 12 October 14th, 2003 17:01
