Boostwerks.com
- Colorado
:flame:Another BWE exclusive!
Replace your OEM manifold bolts and cone washers with our high strength 6Al Titanium stud kit! We include 11 machined Titanium studs that are much stronger than the factory bolts that also provide much greater corrosion resistance. We also include new gold zinc plated 1144 high strength steel cone washers that are also much stronger than the OEM stamped steel washers. Then we top off the kit with high-strength and reusable Mil Spec lock nuts that will not loosen over time.
Benefits of our Ti Stud kit:
- Much stronger than the OEM hardware
- Provides even clamping pressure on the gasket
- Added corrosion resistance
- Easy installation (Studs have 5/32 machined hex)
- Will not loosen over time!*
Kit Includes:
11 - 6Al Titanium Studs
9 - 1144 steel cone washers
2 - Grd8 washers
11 - Mil Spec lock nuts
* You'll need to use some med strength thread-locker when installing the studs in the head.
$115 Shipped!
http://www.boostwerksengineering.com/Jeep-40L-Titanium-Manifold-Stud-Kit-_p_39.html
Kit Includes:
2 - Grd8 washers
$115 Shipped!
