Old June 16th, 2021, 13:49
maxbraketorque maxbraketorque is offline
Rear axle radial and axial runout at wheel mounting hub
As I was installing new drums this morning on my C8.25 axle, I noticed that there is about 1/32 - 1/16 inch free axial movement and perhaps 0.005" inch of radial free play at the wheel mounting hub. My experience with other vehicles is that there should be no detectable free movement, so is this amount of movement normal for a C8.25?
Old June 16th, 2021, 14:11
RCP Phx RCP Phx is offline
Re: Rear axle radial and axial runout at wheel mounting hub
The end play on c-clips axles can be a lot and not un-common. How did you measure what your describing as radial play? The 8.25 uses caged needle bearings. As for end play I don't see a problem unless you are running disc brakes. I shimmed my 8.25 after installing my KJ brakes and wanted more from them.
Old June 16th, 2021, 14:27
I observed the radial runout by feel and watching and I moved the wheel mounting hub up and down with my hands. Drums were off and I moved the hub. It moved quite easily in a radial direction. I don't have a dial gauge and magnet stand at home, but for sure its at least 0.005", and is probably more. I suppose I should invest the measuring equipment to get some solid numbers.
I was surprised that I couldn't find any tolerance values in the factory service manual. It just said something to the effect that if the seal is blown or the bearing is noisy, then replace the bearing.
Amazing amount of axial free play. Would seem to be a bad thing for disk brakes as you suggest. So you tightened that up with some shims?
Old June 16th, 2021, 14:49
End play is disc brakes is as "poorly adjusted" shoes are to drum brakes, it causes the pads to have a lot of take up.
https://naxja.org/forum/showthread.p...=axle+shimming
Old June 16th, 2021, 15:03
Where did you source the shims?
Old June 16th, 2021, 15:15
There was nothing out there with both the od/id correct, I went with the od and modified the id, IIRC!
Old June 16th, 2021, 16:14
ok. I'll see what I can find, probably trying McMaster-Carr first.
Old June 16th, 2021, 16:18
I think that's where I got them from but I order so many thing's!
rear axle wheel wobble iluv83vettes Modified Tech Discussion 3 July 3rd, 2008 17:18
crank radial runout raceready Modified Tech Discussion 0 July 29th, 2007 19:45
215/75/15 Goodyear Wrangler Radial, on wheel 95XJ4.0 NAC Classifieds 0 March 12th, 2007 18:32
Noise, passenger side rear axial. anderld47 Modified Tech Discussion 4 September 21st, 2006 18:12
axle runout, 8.25 gtpolkus Modified Tech Discussion 7 May 8th, 2006 09:05
