What is the cheapest price fyou have seen RE6130?
2001XJ
Canton, MI
Guys.
Can you give me some suggestions on who to go through for a RE6130? Also, will there be a problem with substitutions with the kit? (ex, I want to substitute 4.5" leaf packs for the 3.5's and shackles, and want adjustable control arms versus the fixed)
thanks
2001xj
Susbtitutions aren't a problem; if the reseller says they are then I'd recommend finding another one. I picked mine up from Jeepin.com with a number of swapped in parts and think I still got in at slightly under a grand (including shocks)
Swapped in:
Adjustable LCA
RE HD Trackbar and Bracket
Forgot to swap for JKS Discos
If you already have extended brakelines ask if you can get a credit for those
Guys.
Thanks alot for your help.
2001xj
I got this price list from www.mesa4X4.com.... should be approx. $63.50 S/H...
5.5 Inch XJ Extreme Duty Suspension Lift
RE-RE6200 $960.95
4.5 Inch XJ Super-Flex Suspension Lift (full springs)
RE-RE6130 $695.95
4.5 Inch XJ Super-Flex Suspension Lift (add-a-leaf)
RE-RE6111 $534.95
3.5 Inch XJ Super-Flex Suspension Lift (full springs)
RE-RE6030 $477.95
3.5 Inch XJ Super-Flex Suspension Lift (add-a-leaf)
RE-RE6010 $313.95
3.5 Inch XJ Super-Ride Suspension Lift
RE-RE6020 $239.95
2.0 Inch XJ Standard Suspension Lift (with DT3000 shocks)
RE-RE6160 $172.95
* For four Doestch Tech DT3 Shocks add $125.00
* For four ProComp ES3000 Shocks add $125.00
* For four ProComp ES9000 Shocks add $150.00
* For four Old Man Emu Nitro Charger Shocks add $230.00
* For four Rancho RS9000 Shocks add $290.00
* For four ProComp MX6 Shocks add $290.00
Guys.
So far dc4wd has been the cheapest RE6130 kit is $650.00 then with my add in/substitiutions (upper and lower ACA's, HD trackbar and bracket, 4.5 spring packs) it is $900.00 shipped to my door. Now if I can find that good of price including shocks.....maybe some of these other sites that advertise beating prices will accomodate that price with shocks.
anyone else?
Finally ordered the RE 6130 4.5" Kit with some modifications added/substituted:
HD Adj. Track Bar
HD Track Bar Bracket
JKS Quicker Disconnects
Lower Adj Super-Flex control arms
Dropped Pitman Arm
4.5" Rear Spring Packs
4 Shocks
All this shipped to my door was $1125.
2001xj
