Old January 11th, 2006, 07:25
atreyuBLUEXJ's Avatar
atreyuBLUEXJ atreyuBLUEXJ is offline
sagging springs
weve all heard it, sagging springs. yeh its rubicons 5.5 lift and i have the 1.5 shackles so adding new shackles wont work. i want to do an aal and was wondering if anyone had any for sale? or if you can tell me about blocks? or sell me some? advantages.disadvantages?
Old January 11th, 2006, 07:53
afd516's Avatar
afd516 afd516 is offline
Re: sagging springs
Search all your ?'s have been covered. Especially the blocks.
There is also a forum at the bottom for wanted items and items for sale. Good luck.
Old January 11th, 2006, 13:29
Bronco's Avatar
Bronco Bronco is offline
Re: sagging springs
You need to address the root cause of the sag. Though leaf pack can settle right after being installed, springs do not “sag” from repeated flexing within their designed range. So if they sag, they are being flexed beyond their intended range.
How much weight do you carry while wheelin, do you have a spare on the back, have you extended you bumpstops to match the lift?
AAL’s will address the Root problem also be increasing the springs rate and thus helping to prevent over flexing them. Blocks on the other hand will do nothing but make everything worse.
Old January 11th, 2006, 14:00
KSXJ's Avatar
KSXJ KSXJ is offline
Re: sagging springs
I am going to do a bastard pack to fix my sagging springs.
How do I tell if my leaf springs are sagging? IdeaMan Modified Tech Discussion 11 January 11th, 2005 17:46
Sagging Springs nosajwp OEM Tech Discussion 6 October 14th, 2004 09:43
leaf springs groaning when turning daveleau Modified Tech Discussion 2 December 6th, 2003 12:26
Sagging Springs yardape Modified Tech Discussion 1 July 31st, 2003 23:45
4.5" SPRING'S Frog975 Sierra Chapter 2 June 8th, 2002 16:43
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
