Go Back   NAXJA Forums -::- North American XJ Association > Land Use / Off Topic and other Forums > Non-Tech / Off Topic
Non-Tech / Off Topic The popular Non-Tech Forum. NO SPAM at all. Period.
  #16
Old February 24th, 2022, 08:58
Bent's Avatar
Bent Bent is offline
Stuck In a Rut
Re: Welder Suggestions?
Originally Posted by Bent View Post
I went this route a few years ago.
Yeah, neverminded. The 252 has gone up $1000 since I picked mine up.
Definitely would looking more along the lines of the 215 now.
DEFY LIBERALISM
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ 4.0 AW4 231 Modified
'87 MJ 4.0 AW4 231 Stock-ish
- SoCal Chapter President -
Old February 24th, 2022, 10:51
Anak's Avatar
Anak Anak is offline
Stranger
What hasn't gone up?
Ain't Bidenflation great?
Old July 4th, 2022, 08:57
milarson milarson is offline
The best MIG welder I have ever used is the one I bought at a Sams club on sale for $550.
Its a 180 amp Century (American made, at least when I bought mine) with the cart 220v single phase, infinite heat and wire feed settings. Tweeco handpiece and line. Came with the gas setup, obviously.
I've used several Millers and several Lincolns and I prefer my Century MIG welder. It's the only welder I've used that I can dial it down to where I can weld most sheet metal without stopping and not blow any holes. Maybe my welder is out of the ordinary but I've sure been happy with it. A couple friends of mine have borrowed it who are experienced welders and they both wanted to buy these after using it. I just told them its not for sale.
Old July 5th, 2022, 14:59
SlowXj SlowXj is offline
Welder Suggestions?
The primeweld 180 has had my eye for a bit ... fairly cheap, but I keep eyeballing the hobart 240 as well since that should be a 40 year+ solution
Sent from my SM-S901U using Tapatalk
Old July 12th, 2022, 11:06
Phil's Avatar
Phil Phil is offline
My Millermatic 180 is almost as old as this thread and hasn’t ever given me trouble, for hobby use.
Spotters lead the way!
My green junk. or #StellaFTH4
1989 XJ Wagoneer. Basically stock.
G & G Offroad and Auto Repair can make you think you can run the Box!
Rate This Thread:
farmhand welder, opinion pls goin4wheelin Non-Tech / Off Topic 8 December 28th, 2004 11:18
Any suggestions on a good first welder?? climberjeep Modified Tech Discussion 4 August 22nd, 2004 09:28
Need Tig Welder advise ! hackedxj Non-Tech / Off Topic 10 August 10th, 2004 06:09
Wire or stick welder, help me decide. JEONLYEP Modified Tech Discussion 15 December 23rd, 2003 08:53
Regular MAintenance suggestions jeepster1985 OEM Tech Discussion 2 December 8th, 2003 14:56
