Go Back   NAXJA Forums -::- North American XJ Association > Land Use / Off Topic and other Forums > Tools and Garages
Tools and Garages This is a place to share about the tools and workspaces used to craft your latest masterpiece.
Old April 1st, 2022, 10:14
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
Battery Load Tester
Replaced the battery in my DD this week as it was showing signs of failing, and once again I got to thinking that maybe I should look into adding something that can load-test that sort of thing to my tool collection (I have a DMM).
Seeing as it's not something I expect to use a lot, I wouldn't want to spend a huge amount on it. As such, I've been occasionally eyeing this simple, old-school load tester from Harbor Freight that's only about $20:
https://www.harborfreight.com/100a-6...isolation=true
Overall review rating is 4.7 out of 5, and it seems like there's very little in terms of things that can go wrong with it.
I'm thinking that at the price it may worth picking one up and taking the chance - Anyone around these parts used one of these?
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old April 1st, 2022, 10:55
jeep ride's Avatar
jeep ride jeep ride is offline
Re: Battery Load Tester
Yes we had those at the Napa's I used to work at worked great easy to use can't remember the brand looked like the one in your link ours were much more than 20 bucks fwiw.
Old April 1st, 2022, 22:03
Bent's Avatar
Bent Bent is offline
Stuck In a Rut
The HF unit is worth the price of admission. I have one, worked the few times I've needed it. Former neighbor had one he used all the time. He liked it.
DEFY LIBERALISM
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ 4.0 AW4 231 Modified
'87 MJ 4.0 AW4 231 Stock-ish
- SoCal Chapter President -
Old April 2nd, 2022, 09:10
NAXJA Member #920
Thanks for the feedback, guys. Will probably grab one the next time I pass by my local HF.
1984 Dodge Omni
Old April 2nd, 2022, 14:39
Bent's Avatar
Stuck In a Rut
Forgot to mention. My former neighbor works on traffic signals and controllers. Many/most have lead acid batteries for back up. So yeah, he uses the $hit out of it.
DEFY LIBERALISM
Old April 8th, 2022, 06:08
old_man's Avatar
old_man old_man is offline
All a battery load tester is, is a big resistor. No complex electronics. No reason to spend big.
Tom Houston - Former Colorado Chapter President, current Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old April 19th, 2022, 10:18
NAXJA Member #920
Well, I did buy one the next time I happened into HF. Haven't tried it yet, doing cylinders/shoes/hardware on my rear drums is slightly higher priority.
Looking forward to trying it though...
1984 Dodge Omni
Old June 21st, 2022, 13:48
WCBlueSky WCBlueSky is offline
Good info and link, thanks
Old July 31st, 2022, 21:11
RickDT RickDT is offline
Looking to get one! Good to hear they are reliable.
Old August 7th, 2022, 22:12
Bent's Avatar
Stuck In a Rut
One thing I've never seen there is a hydrometer. Handy to have if you have any wet cells in your stable. It's sad and funny when someone is having issues and you ask them, "have you checked the water levels?" "Huh?"
DEFY LIBERALISM
Rate This Thread:
anyone run Dana 30 bearing cap load bolts, ring gear load bolts, and girdle caps? blondejoncherokee Modified Tech Discussion 16 October 21st, 2013 12:31
battery load userbmx1315 Modified Tech Discussion 7 December 27th, 2007 07:21
tester XJerome TEST Forum 4 July 2nd, 2007 18:47
tester MauriceGOL TEST Forum 0 May 7th, 2007 09:45
tester zak8642 TEST Forum 29 January 13th, 2006 01:33
