Okay, the problem...at an about 1800 rpm, almost wants to quit, not getting fuel/spark...kind of a close to back-fire feeling.
Now I have replaced in the last two weeks, fuel pump, cap/rotor, plugs/wires, cleaned the TPS, new CPS, New O2 sensor, hooked the coolant temp sensor back up (don't know why it was unhooked), replaced the MAP with a working good one, new fuel filter. No way to pumping the EGR, doesn't seem to have a diaphram to pump (may be wrong???). I have taken the fuel pump out again to make sure the float is correct it is. Now I'm thinking to take it back out to make sure it's sitting right (again). Also checked the vacuum lines and jumped the fuel ballister.
Any other ideas, I'm running out of hope. Thanks Juice
