Mopar 240/240
140657
Lewes DE
I am hopeing that the powers that be will be able to help me out with this problem. I have a 94 Xj with a 96-98 4.0 ( block casting and head casting numbers). Do to the bearings in the distributor going out and taking a chip out of the cam gear I am now looking at getting a new cam. I came accros the Mopar performance 240/240 (summit racing part number DCC-4529228AB). My question is can I run this cam with the stock valvetrain. I will be replacing lifters and the cam and hoping to be able to get away with not repacing valve springs and what not. Any help would be greatly welcomed.
Andy
You can use the stock valvetrain with the 28ab. I'm running the 30ab in my stroker and had to use the 5249464 springs for the additional lift.
Absolutely yes. The stock valve springs are rated up to 0.430" of valve lift which is exactly the same figure for that cam. You're good to go.
