G/f still has the 98 XJ and she's going to be in stamford and who knows what other cities for work this summer, i was wondering, on the pass. side in the fuse comp. there is a fuel pump fuse that if u pull the pump shuts off, is there any way to rig some kind of toggle switch i can mount under her dash so when she parks she can flip the switch to somehow disconnect that fuse as if you were removing it? If not, what are some other easy ways "on off" switch ways to completely disable it when parked? Thanks for any help.
