After I completed swapping a ax15 for the aw4 in my 92 4.0 XJ I have been wanting to get my cruise control back and my reverse lights to come back on. Since day one of the swap I have had a small connector completing the continuity of the "park" signal between the B and C connector allowing me to start the jeep.
To get my cruise control to work again I would just need to be able to make sure there is zero continuity making the NSS think I am in "drive." And Finally to get the reverse lights on I want to be able to complete that continuity with the reverse light switch that is on the ax15. At least that's how I think the switch works since there is no power running through it.
Does anyone think it is possible to make a box with a multiple position switch that would allow me to control the continuity of which "gear" I want from the drivers seat? Or a toggle switch with more than two selections? So I could have the box selector in the position of "park" when I want to start my jeep, then select "drive" when I want to use cruise control and "reverse" will be engaged when I actually put my ax15 in reverse completing the continuity at the transmission?
