barillms
- Eastern Ohio baby!
Question:
With 6.5" of lift I have a Rubicon Exp. HD track bar with the flex joint end.
I have chopped off the ball joint mount area of my stock track bar frame mount, and am fabbing up a new mounting bracket for the new style RE flex joint.
Using my modded stock frame mount, I will be lowering the upper track bar mount a small amount, maybe 1" or so lower than the factory ball joint.
I have not finished the job, I'm am still working on it.
Should I make the mount lower, like an aftermarker drop mount? Say 2-3" lower. Or keep the mount relatively close to the stock mounting position?
