Front sway bar size?
keyoctave
North Carolina
I am wanting to replace my bushings on my front sway bar. The size offerings are 23, 24, 25, and 28mm. I have a 1995 Country with 4.0L, 4WD, a/c, auto trans, and select trac. It has the standard stock suspension (nothing heavy duty). Build date in 7/95. Does anybody know what size it is?
Thanks!
you will have to measure sway bar with digital caliphers to figure this out
That's exactly what I had to do......why couldn't they make a one size fits all?
They should have a caliper at the auto parts store you can borrow.
Thanks for the replies!
I'll go the caliper route and see what size I have on mine. Seems like Jeep did the sway bar thing like the rear diffs. Put on whatever is availible. (at least you can tell the rear diffs apart by looking at them).
