Old March 2nd, 2019, 19:15
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Re: Gratuitous Lack Of Moderation - A little stroker build
Originally Posted by Weasel View Post
what are you using to prime the motor once it's all together?
The same thing I have used for the last three.
https://www.naxja.org/forum/showpost...postcount=1381
Old March 2nd, 2019, 19:21
cal's Avatar
cal cal is offline
Originally Posted by freerider15 View Post
So...what the running total on this stroker build?
More than I budgeted. Less than you'd think. We re-used a lot of parts from 4643 and Russ gives me the buddy deal on a lot of stuff. Out of pocket I'll be an average stroker build in cash. If you subtract the head and the gratuitous bling stuff, under $1500.
Part of that though is my accepting the risk that this could be way too much compression and the whole thing has to come apart to be redone. Russ would probably feel pretty bad if that had to happen, but not at all on the same level as he would if it were a customer engine.
Old March 2nd, 2019, 19:25
cal's Avatar
cal cal is offline
Just looked up the price of that oil pan...
****in OUCH!
Thankfully Russ is a Moroso dealer, so the hit wasn't as bad as you think.
Which is good because I needed that savings to buy a fancy red valve cover from Crown and 3 stud kits so I can stud both the pan and valve cover. Because gratuitous.
Old March 3rd, 2019, 12:02
Weasel's Avatar
Weasel Weasel is offline
perfect, thanks. I have a buddy doing a rebuild and he was asking around and I hadn't thought of it before.
Just add lightness
Old March 3rd, 2019, 23:27
rockclimber's Avatar
rockclimber rockclimber is offline
Associate
is this thing done yet?
[cal]You're an idiot rockclimber.
[StinkyFab]RockClimber is a tool.
Old March 4th, 2019, 11:13
Weasel's Avatar
How's the up travel clearance with that pan? Assuming this isn't the first time you have used it.
Just add lightness
Old March 4th, 2019, 11:14
cal's Avatar
cal cal is offline
They claim no change in clearance.
This is in fact the first time I have used it, so we'll have to see.
Old March 4th, 2019, 14:42
Weasel's Avatar
have you considered running crank scraper/ windage tray?
https://www.crank-scrapers.com/amc.html
Just add lightness
Old March 4th, 2019, 14:50
cal's Avatar
cal cal is offline
We've discussed it but we don't turn enough RPMs that Russ thinks it's worthwhile
Old March 5th, 2019, 07:04
cherokeecrawler's Avatar
cherokeecrawler cherokeecrawler is offline
****in OUCH!
I looked up that head he put on there and its an "OUCH" too..
Old March 5th, 2019, 10:43
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Have you or others you know had problems with the stock oil pan causing engine issues?
Just wondering if the new pan is there to prevent existing problems or it just looks good...or both.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, 4.6L Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old March 5th, 2019, 10:47
cal's Avatar
cal cal is offline
I can't say that we *havent* had problems, but I also can't say that we *have*.
The road race cars have had problems with starving for oil on long hard corners, and solved it with an accumulator - but that presents some of its own problems (overfilling the oil pan when you're at lower RPM's with less oil pressure).
In this case, the oil pan is probably gratuitous. So are the ARP oil pan and valve cover studs that you haven't seen yet.
Old March 6th, 2019, 00:08
Associate
Old March 6th, 2019, 09:00
cal's Avatar
cal cal is offline
tomorrow maybe, or friday. we just need to drop lifters in it, drop the head on and setup the rockers, bolt some tin together.
its just a matter of both Russ and I having free time at the same time.
Old March 7th, 2019, 10:22
bajabronco bajabronco is offline
Great build Cal! I have been lurking, following your build for awhile. I finally contacted Russ last week and got in line !
Stroker build kf_chris Modified Tech Discussion 33 January 4th, 2010 20:21
99 xj stroker build WHITE93 Modified Tech Discussion 1 May 2nd, 2009 11:25
4.6L Stroker, Help me build it please! XJoshua Jeep Street and Performance 277 February 28th, 2009 00:18
Stroker Build missionstroker Jeep Street and Performance 15 December 12th, 2007 07:08
Want to build a Stroker? robert stalberger For Sale: Private Party Only. XJ ITEMS ONLY 1 September 12th, 2006 14:08
