goodburbon
- Westcliffe Colorado.
I have a 1997 4x4 4 door with the 4.0 and the following mods.
Open element air filter
home bored throttle body
1" throttle body spacer
3"custom cat back exhaust
Jacobs Electronics Pro street ignition (plugs gapped at .50)
Electric fans, (mechanical one eliminated)
Jet Performance stage 2 chip
180 degree thermostat
optima yellow top
and a few drivetrain and suspension mods
Here is the problem. Sometimes it doesnt want to start, and I keep getting check engine light, sometimes it dies when approaching a red light. The Jacobs kit is advertised to eliminate all of these conditions. I have changed map sensor, throttle position sensor, oxygen sensor.
It will always start if I hold the throttle wide open while starting. no blue smoke, but I will get smoke if I start it with throttle wide open, smells rich.
should I just strip it back to stock to see if everything works and jut add things one week at a time to see if its something I have done?
optima yellow top
