Old May 29th, 2008, 10:00
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
Power Door Lock Fuse Keeps Blowing
Last Wednesday my power door locks quit. I pulled the fuse, and sure enough it was blown. I replaced it thinking it may have been a fluke, the locks worked, and I left the Jeep parked for a week.
Last night I took her out, drove to a friends, hit the lock button to lock the doors and got nothing. Fuse blew again. I replaced it as I keep some spares with me, and went to lock the door and still got nothing.
What would be causing my power door locks to constantly blow fuses and quit?
John V.
RRC VP
01 XJ Sport 2 door 5spd/4WD- 4" lift, Rubi wheels/tires JCR bumpers/sliders, armor, Rubi 44, Ford 8.8, 4.56's, ARBs.
Old May 29th, 2008, 10:18
Tim_MN's Avatar
Tim_MN Tim_MN is online now
Freakish Hand Strength
Re: Power Door Lock Fuse Keeps Blowing
A short circuit will blow a fuse, any fuse. Check the wires in the door hinge rubber boot for a broken wire. Trace the wires back to the switch looking for problems. Inspect the switch for dirty contacts or signs of arcing.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Old May 29th, 2008, 11:03
XJ Stryker's Avatar
XJ Stryker XJ Stryker is offline
WHO DAT!
X2 you got a short to ground somewhere you will want to check your connection and then trace your + wires back and find where it is effed up
Pass. Door Lock blowing fuse? MoparManiac OEM Tech Discussion 5 April 27th, 2008 18:38
power 4 dr. lock kit... on a 2 door... where to put the 4th door lock? selarep Modified Tech Discussion 2 April 22nd, 2007 20:52
power outlet fuse keeps blowing dakotus OEM Tech Discussion 10 June 14th, 2005 17:51
Fuse for power locks keeps blowing Scriff OEM Tech Discussion 5 March 4th, 2004 17:41
Right Rear Power Door Lock drassmantis OEM Tech Discussion 0 December 28th, 2003 14:33
