Old January 23rd, 2008, 10:51
rooneypower's Avatar
rooneypower rooneypower is offline
rock rail Qs
Is there any lines i shouldknow about in the sub frame of an XJ before i drill the holes to mount my rock rails?
Also, what size bolts should i use for mounting it to the frame?
Thanks
Old January 23rd, 2008, 10:53
userbmx1315's Avatar
userbmx1315 userbmx1315 is offline
Re: rock rail Qs
the fuel lines on the drives side
Old January 23rd, 2008, 10:58
joshv98xj's Avatar
joshv98xj joshv98xj is offline
Re: rock rail Qs
Those lines are not contained or hidden inside the "frame rails".
They are however to the inside of the frame rails. That sounds really confusing.
It shouldn't be though- you can see the fuel lines, they're mounted on the exterior of the frame rail, towards the inside of the Jeep.
Old January 23rd, 2008, 10:59
Re: rock rail Qs
k thanks, what about bolt size??
Rock Rail Q's? jeeper01 Modified Tech Discussion 5 October 19th, 2007 17:57
Rock rail install XJSTANG Modified Tech Discussion 1 July 31st, 2006 06:22
rock rail tech SourApple Modified Tech Discussion 6 February 24th, 2006 06:55
Rock rail welding JMLichner North Atlantic Chapter 1 January 6th, 2004 19:44
Yet another Rock Rail Ques. csudman Modified Tech Discussion 9 October 6th, 2003 18:07
