Old August 8th, 2018, 19:08
Creebo92 Creebo92 is offline
New to me renix build
Purchased this 89 about two months ago for $800. Ran great but needed a tranny. And had some overheating issues. Slapped a $200 transmission in and bled the coolant it and started abusing it.
Sent from my E6820TM using Tapatalk
Old August 8th, 2018, 19:14
After multiple trips to our land, I took the jeep to the gulches in Laurens Sc. I will try to link a few videos from the trip. As we were making our way back to the trailer the motor developed a loud nock and started running rough.
Old August 8th, 2018, 19:22
And here we are today. Motor is pulled. And tear down is complete. The loud knock was the cam sliding forward and hitting the timing cover. During disassembly I inspected the rods bearings and found pretty bad scoring. A full rebuild is in order. I would love thoughts as well as any advice as this is my first jeep build after owning several Toyotas.
Old August 9th, 2018, 10:12
old_man's Avatar
old_man old_man is offline
Re: New to me renix build
What does the bottom end look like?
Tom Houston - Former Colorado Chapter President , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old August 9th, 2018, 14:04
I'll unbag a few bearings this evening and post photos. But I thought it was pretty ugly.
Old August 9th, 2018, 16:09
Here is the number 6 piston,rod cap, and bearings.
Old August 9th, 2018, 16:19
Old August 9th, 2018, 16:31
https://photos.app.goo.gl/ePTmMtkifRppVug57
Old August 9th, 2018, 18:27
trippled trippled is offline
Yea that bearing definitely looks pretty worn out
Old August 9th, 2018, 18:29
Best I can tell it's the original motor. And the odometer has 230k on it. I'm assuming it's had a pretty hard life.
Old August 9th, 2018, 18:32
I'm planning to call around tomorrow. But does anyone have a rough guess as to what machining is going to cost? Also where should I purchase my master rebuild kit from?
Old August 9th, 2018, 22:42
CJ'sXJ CJ'sXJ is offline
About 15 yrs ago, I had my '89 rebuilt. Machine shop got the engine in pieces, we disassembled. Reused the crank & rods, bored 40 over, decked and balanced. Shop supplied bearings, pistons, rings, new stock cam and most of the gaskets. They also assembled the heads with new valves & springs after I had ported it. Was a very reputable performance machine shop, cost was just over 1k at the time. I still have it and am happy that I spent the money, but if I wasn't planning on keeping it a long time, I would have picked one from a jy, a lot cheaper. I did replace most of the accessories and upgraded to the later cooling system/t-stat housing, new flexplate and balancer, ect. Total cost was a little over 1500 at the time. Not including a 6-2-1 header, bored throttle body and a few other items. Hope this helps, know it was a long time ago!
Old August 10th, 2018, 05:13
That's roughly the cost I figured. Though I have thought about upgrading to a comp cam. And I have thought about going the jy route but the closest yard to me that has one is an hour away. They want 450 for a 200k motor. I Guess I should get on the horn to the local shop.
My buggy build....... well, continuation of a build. YELLAHEEP Colorado Chapter 39 November 17th, 2016 23:49
Renix head in stroker build PacificEd Jeep Street and Performance 8 February 3rd, 2015 04:02
1988 Renix to 1991 Chrysler conversion Renix ABS/Factory Alarm Questions dwcjwerfner OEM Tech Discussion 3 May 4th, 2012 09:07
anyone in cali swap a HO in a renix yr and pass smog like its a renix? RWKHausSupply Modified Tech Discussion 8 January 30th, 2006 13:55
Hodge's Renix Stroker Build up. HodgePodge Jeep Street and Performance 17 February 8th, 2005 14:06
