Old July 31st, 2018, 08:49
Lawsonmahoney Lawsonmahoney is offline
NP242 install question
After installing a lift on my 1988 XJ, instead of buy a new SYE, I got another NP242 from a Ď98 with the SYE already installed from another forum member.
Iíve installed the case, bolted up the shafts, changed the fluid. Put it in gear... nothing. It doesnít click like itís going into gear when I try to go from neutral to either reverse or drive. Under power itís like the TC is in neutral. When I try to put it in park it makes a light grinding noise so Iím leaving it in neutral.
I shifted the selector on the TC manually by hand to get it into what I believe is 2WD. Tried again with the same result. I then, from the cab, tried shifting into everything from part time to full time to neutral to lo. Nothing. I cannot for the life of me make it move.
Any thoughts? The videos and write ups I saw didnít make putting the TC back in to be a big deal. Just slide it in after youíve lined it up with the bolt holes and youíre good. Or so I thought.
Old July 31st, 2018, 08:58
RCP Phx RCP Phx is offline
Re: NP242 install question
Did you change the input shaft gear? Yours is a 21 spline. the '98 is a 23 spline!
Old July 31st, 2018, 09:04
Heavyopp Heavyopp is offline
if this is true then how did they even fit together?
Unless they didn't...
Old July 31st, 2018, 09:09
That isn’t something I changed. From what I’d read, retrofitting the case was limited to the speedo cable and 4wd selector light.
Everything fitted together smoothly. No forcing at all. So that’s a bit of a surprise. And an obvious bummer.
Old July 31st, 2018, 09:12
Oh it will bolt together! It wouldn't if you tried to stick a 21 spline case on a 23 spline shaft!
Old July 31st, 2018, 09:32
Be aware of the fact that your '88 input gear will not work in a '98 case.
Old July 31st, 2018, 09:51
Thanks for the help RCP. Why won’t my 88 work? BleepingJeep did a video where he did the swap for a 231. He had to use the front of the old case because of bearing size but other than that everything bolted up Ok.
Old July 31st, 2018, 10:01
It's the cut of the gear.
https://www.novak-adapt.com/knowledg...g-input-gears/
Old August 1st, 2018, 06:35
cruiser54's Avatar
cruiser54 cruiser54 is offline
I'm guessing the 21 spline output shaft of the trans is spinning inside the 23 spline female transfer case input.
Old August 6th, 2018, 13:17
Novak conversions no longer sells the 21 spline with the late model cut. Does anybody have any idea where you can get an input shaft that you can use to make a late model 242 work with a early model 21 spline trans. All I can think of is either swapping the whole trans with a late model one or just trying to get rid of this late model TC and starting over.
What about swapping the planetary gears from my old TC and using the input shaft from that as well? I’m assuming that’s just not possible..?
Old August 6th, 2018, 15:15
While swapping the planetaries "is" possible, not without a machine shop!
Old August 9th, 2018, 20:30
lawsoncl lawsoncl is offline
Going newer than a 97 means your trans computer won't work. 97 involves a bit of cutting and splicing of connectors.
"Everything you ever wanted to know about the AW4"
https://www.naxja.org/forum/showthread.php?t=1053970
NP242 New Chain install Xhavier_5478 OEM Tech Discussion 13 January 16th, 2015 18:20
opened my NP242 for SYE install, now some bearing/chain questions md21722 OEM Tech Discussion 1 September 16th, 2014 21:33
NP242 Sye install question SubFreq111 Modified Tech Discussion 10 December 10th, 2013 05:31
NP242 Tom Wood SYE install help Oil Town XJ Modified Tech Discussion 0 April 23rd, 2007 20:10
NP242 Slip Yoke Eliminator Install Flyfisher Modified Tech Discussion 8 December 2nd, 2004 17:11
