98 Cherokee Classic XJ - Fully Built Rock Crawler/Daily Driver
Cruzzin_XJ
CO
1998 Cherokee Classic XJ - Fully Built Rock Crawler/Daily Driver -
Power Windows, Power Door Locks, Heated Power Mirrors
Cruise Control, Upper Computerized Consol, Temp, Compass, MPG,Trip Distance Etc.
Alpine CD MP3 Stereo with Pyle Amp, dual 8" Woofers and Boston door and roof Speakers
AC/Heat works Xlnt
60k miles
Drive train
Engine - 4.0 High Output 60k Miles Always used as a third Vehicle
Venom CPU Controller, Stainless Borla Header, Custom Cat, Cat Back and Flow Master Exhaust, MSD Ign, Wires and Box, Air Aid Air Cleaner, Throttle Body Spacer,
(Spare CPU just in case) ARB Air Pump to Run Lockers, Red Top Optima Battery, with Custom Bracket hold down
Transmision - 4 Speed Automatic with Over Drive 60k Miles
Fresh Fluid Service, Trans Cooler, Comptuer controled 1st gear lock (Accushift) Custom Crossmember, with 3/16" thick Skid Plate
Transfer Case - Atlas 5.0 Low Range Twin Stick Less than 5000 Miles
Atlas 5.0 Transfer Case 2 speed case with custom Cross Member and skid plate 32 spline front and rear, Tom Woods CV Shafts front and rear. - plus spares for each
Front End - Custom High Pinon Dana 44 - 5000 Miles
High Pinion Dana 44 with ARB Air Locker, 4.56 Gears, Custom Alloy Shafts, CTM U Joints, Custom High Steer Steering , Crane Diff Cover, - Over Sized Disk Brakes off Full Size Wagoneer and spare inner and outer axel shafts with U-Joints for both Sides
Rear End - Custom 8.25 Chrysler - 1000 Miles
Rear Chrysler 8.25, ARB Air Locker, 4.56 Gears, Dutchman Alloy Shafts with Spares, Grand Cherokee Disk Brakes, Crane Diff Cover
Suspension Lift and Rims and Tires
Custom Long Arm 9" Suspension, Rock Crawler Coils with ACOS adjustable coil mountsand bup stops, adjsted at 1" lift, 8" Custom Alcan Rear Leafs, 1" lift Rubicon Express lift Shackles, Rusty Long Arms, Bilstein and Rancho Shocks, Custom Rear Bump Stops, Tri County Gear Track Bar relocation and suport Brackets, 1-1/2" 1/4 wall DOM Drag Link, and Track Bar with Hiem Joints - High Steer
(5) - 15-10 589 Alum Modular Rims with Near New 37" Goodyear MTR's Maybe 1000 miles
Body - Exterior
Front Light Weight Full Stinger Winch Bumper with 9000 Warn Winch and Roller Fairlead, Extra Bracketing on Front Crossmember for Flat Towing
Draw Tight Tow Bar, fully Disconect - Take 3 Minutes to install or take off not Bolting all pinned.
Rear Fold Down Stinger Tire Carrier Bumper very Custom, just like Poisen Spyders for TJ, only one that i no of on a Cherokee - Mounts to 3/16" thick Side Armor and pivots on lower part of Bumper crossmember.
3/16" Thick Side rear Quarter Armor with built in Rear Quarter Panel Skid Plates, don't need to worry about rear over hand.
3/16" thick Door Guards, and Fender guards
Custom Side Rocker Bars on upper rear Quater, adds protection when Cherokee want to whip against rocks in rear quarter. Keep window from being knocked out.
Rusty's Fender flares cut for tire Clearance
1/4" Stel Side Rockers with Body Plates for High Lift mounting to lift Jeep
Trans Am Hood Vents to allow Engine Heat to Exscape
Interior
Full custom 8 point Interior Cage, 1-1/2" 120 wall Cage with Dash Disconet aand Rear Stabilizer Hoop
CO2 Bottle Mount on Cage
Over 35k put into this Jeep over the last 5 years Runs very good, normal Trail Scares, Some Dents from wheeling, but nothing major
$15000
Email for Pictures
Email John @ [email protected]
Sent you to your email
