shawnravish
- Cartersville GA
I have a 2001 XJ 2wd, 4.0L manual tranny. My ac/heater blower motor has quit working all together with no warning. I have been searching in forums for my exact problem, however the only info I could find is on the blower only working on HIGH, and most people said to look at the resistor for this problem. I have verified that the motor itself works by taking it out and connecting direct power from the batt to it. I have also checked all the fuses in the eng. compt and on the passenger side wall. The only fuse that I found that might have to do with the problem is in the engine compt and is one of those big sized 40amp ones, (the cover listed it as "blower motor" I replaced this and still no luck. I do not have a diagram to show which fuses in the pass. compartment are for what, however all fuses look to be fine. I can not find any ref. to there being a relay or anything, so not sure if there is or not. I have taken apart the panel on the dash, and could not find anything that stands out as broken or burnt, and the switch that controls ac/heat/defrost etc is working, so I assume that the panel is getting power.
Could the problem be the resistor?, is there a relay somewhere?, should I just try to replace the switch?, or is there anymore troubleshooting I could do.
Thanks for any help!
