Ironmanandy
- North Carlolina
STEERING BOX BRACE with SECTOR SHAFT SUPPORT JEEP XJ/MJ!
One of the most neglected parts of an XJ Cherokee or MJ Commanche build is the steering box. Having no true frame to support the thousands of pounds of force created with increased stress, angles from lifts, and oversize tires, often leads to disaster.
161.50 SHIPPED is a steal for 10.9 graded frame mount bolts, grade 8 clamp bolts, 1/4" and 5/16" construction.
199.50 SHIPPED for the brace with the same specs listed above but with the sector shaft bearing and brace added for UNMATCHED BOX RIGIDITY!!
We found that without the clamp and brace we had just under 1/4" of flex at out sector shaft. Using just the clamp we eliminated that down to under 1/16" on the dial indicator and with just the sector shaft support it was about the same. When we combined the clamp and the sector shaft support we had .003 of deflection. Yes 3 thousandths of an inch which could be purely mechanical variation.
This brace also works with the DURANGO BOX conversion as long as it is spaced .200-.240 wider than the factory spacer. These can be purchased un-welded if you need to mod it to a heavily damaged and repaired setup!
Click here to order now!
http://www.ironman4x4fab.com/Products/SBB-SSS-MOB.html
