Black1990jeep
- california
For my 1990 Renix six cylinder, I have a SnapOn MTG2500 scantool attached for trouble shooting. The scantool tells me the ecu is staying in open loop mode.
Per the scan tool...
a. The O2 sensor is operating, fairly steady at near 2.5 volts or so at warmed up idle, and does increase when motor is reved. the O2 sensor is fairly new only a few thousand miles on it.
b. Both short and long term fuel trim is at 128, which I understand to be correct for open loop operation
c. coolant temperature is 187F
b. injector pulse is about 5 when warmed up at idle, when cold shortly after start it was about 9.
What might be the problem that is preventing closed loop operation?
Thanks!
Thanks!
