on our bumpers we go into the frame rail and replace the nut strip with a bracket. This is going to be the strongest way you can tie into the cherokee unibody.
As far as the bumpers go, most bent plate bumpers are not going to have the strength to prevent twisting when using much tongue load or even a drop hitch.
If you are doing a DIY kit you can easily build the center like a standard hitch with a square tube subframe and then put the bumper skin on the front.
We do have a way to address this issue in the next revision of our kits and bumpers, but I don't want to go into details until it's been put through production and fully tested.
Without more reinforcement, I wouldn't use the JCR bumper for real towing. Couple jetskis or a small 5x8 trailer up to about 1500 lbs, sure. 3/16 is all that holding that receiver in. The recovery points are welded directly to the frame mounts so they can take a lot more force. Don't get me wrong, its a solid bumper and I backed into a tree at about 10mph and had just a tiny dent right where the cutout for the safety chains go but I wouldn't trust a big load to it. It's not certified and imagine the field day a lawyer would have if you lost a load because of a failure. You're now negligent and can't pull the defective equipment defense.
I have never seen any bumper (commercial or homemade) that attached as well as the detours tailbone http://detoursusa.com/tailbone_install.php
I used this on my previous jeep, then removed it before selling. I had it blasted and ordered all new hardware from detours before installing it on my current XJ. A tailbone would be a great starting point if you wanted to replace the stock bumper skin with some thicker metal, or you could take some inspiration for your mounting points from it.
Resurrecting this post.
I have a '99 XJ with factory tow hitch and I'm looking to put a JCR rear tire carrier bumper on there reinforced with JCR rear frame stiffeners and also with these:
https://www.ebay.com/itm/Fits-1986-...-Brackets-DIY-Fabrication-Ver-2-/163691598618
Should I have any concerns being able to pull a teardrop camper (less than 2,500 pounds) with the JCR bumper reinforced so?
That's not to bad on trailer weight, I'd be more concerned that the is not re-enforced enough for a tire carrier.
https://naxja.org/forum/showthread.php?t=1160514
I've discussed this extensively with the shop (Mount Zion Offroad).
Right now, the plan is for:
JCR rear bumper with tire carrier
JCR rear unibody stiffeners (welded on)
JCR rear unibody tie-in bracket
Circle-S rear bumper brackets
This should result in an off-the-shelf set up pretty close to what you show in that thread.
I really can't think of anything else that I can do to beef things up.
Will Uhaul look for a certification sticker?
