Old June 26th, 2019, 01:31
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
99 wiring harness p1,p2 pcm to ignition, up 2 u
Hey folks,
So lately I have a friggin laundry list of jeep problems starting. I'm these quests I've picked up a JY harness to ignition side of things.
I have no questions yet, but mainly I decided to post this for anyone that wants to see under the shething, any splices on this harness. It's one of the few things we ever see on these old machines.
Anyhow let me know if any photos are of use to you and I'll try to get a good one.
Right here I tore open the part that goes behind the valve cover. There are 4 splices along just here and I'm not to impressed by the cleanlysness if the weave. With that said I'm no accomplished electrician, but I can bang rocks together so hey, genius here.
In this section alone I've found wire pinched/ rubbed through to bare wire in a few locations. If you suspect any wiring issues, or you even have downtime for some preventative maintenance, I highly suggest taking these harnesses for a walk through, I've learned so much in 5 minutes of looking at this.
Thread is yours folks,
Cheers.
Old June 26th, 2019, 06:01
RCP Phx RCP Phx is online now
Re: 99 wiring harness p1,p2 pcm to ignition, up 2 u
I don't know if I ever showed you this....... https://naxja.org/forum/showthread.php?t=1145993
Old June 26th, 2019, 14:35
Yessir you did, but its for your 2000. No idea if its different, but I figured what the heck, it's useful or not lol.
Old June 26th, 2019, 14:43
It's close, there are not many changes between 97-00.
WTB 2000 XJ Engine Wiring harness and/or Complete engine with wiring harness Better_than_Tom SoCal For Sale 28 July 22nd, 2013 18:56
Accel ignition coil adapter harness 98+ OverlandZJ Wanted: Private Party Only 0 September 16th, 2012 09:07
99 Blower control wire in ignition harness npcherokees OEM Tech Discussion 6 November 27th, 2007 16:02
ignition/starter wire harness help, HOTWIRE IT!!! dimmwatt OEM Tech Discussion 2 September 24th, 2006 15:03
color coding for ignition switch harness Micha OEM Tech Discussion 0 September 7th, 2004 11:50
