Old July 1st, 2018, 12:46
90xj06's Avatar
90xj06 90xj06 is offline
88 Cherokee a/c line thing
1988 Cherokee 4.0. suction line has a bump in it. Is it a muffler? I have reason to believe what ever it is has gotten clogged as I'm frosting up on it. I just replaced my dryer and noticed this. Also there is some kind of valve thing that connects to the dryer does it also have a name?
Old July 2nd, 2018, 05:42
JeepNoob JeepNoob is offline
Re: 88 Cherokee a/c line thing
Got a pic? If it's on the low-pressure side, some condensation on it may be normal depending on the amount of humidity in your area.
Old July 2nd, 2018, 05:54
cruiser54's Avatar
cruiser54 cruiser54 is offline
It's a muffler.
Old July 2nd, 2018, 06:18
90xj06's Avatar
https://photos.app.goo.gl/wAeVy4X9wvYmssA87
got a bit more than condensation. added a bit more r-152 and it melted away. high side was a smidgen higher than id like but it was about 95 with a 80% humidity.
Old July 2nd, 2018, 07:21
Saudade's Avatar
Saudade Saudade is offline
I took some closed cell foam and wrapped it, secured with tie wraps. The wrap extends beyond the metal fittings.
How's the 152 working for you?
1988 Laredo 2wd Auto, AKA "Grey Ghost", 206K
Old July 2nd, 2018, 08:01
90xj06's Avatar
its been working great. did some adjusting to the evaporator temperature switch to cycle off at ~40 and back on at ~50.
but i got a hole in my condenser over the winter and after replacing that im having some issues. just slowly going through everything. i have a noisy compressor so i may swap in a 91+ compressor setup with r134 ports for ease of service.
Old July 2nd, 2018, 09:54
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
You'll need to go later than '92 - mine used R12 from the factory (been converted to 134 for something like 12 years now, though).
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old July 4th, 2018, 07:00
Saudade's Avatar
The ac brackets are different from Renix to HO. I think the '92 bracket will mount to the Renix block if you can source one.
When mine seized a while back, I looked at an "upgrade", rather than a conversion. After all the tradeoffs, decided to remain with year correct parts. At the time, although still more expensive, R-12 was easily acquired (yes, I'm 609 certified). I didn't care for the alternatives under SNAP at the time. I still have 2 cans of R-12 left.
Old July 4th, 2018, 07:04
90xj06's Avatar
Normally I would leave it period correct. But the compressor is starting to make noise while idleing.
There are a few at my local yard I could source brackets and parts. I might just go with a new compressor and hoses. Essentially replacing everything but the evaporator.
I also have 2 cans of R-12 and I just can't give them up or use them.
Old July 4th, 2018, 19:50
Overland's Avatar
Overland Overland is offline
I'm looking to build a 90 with compressor, condenser, and lines from an 01.
Did you get a multi pass condenser or single pass like the original?
Old July 4th, 2018, 19:53
90xj06's Avatar
OEM Style looked like a single pass.
Old July 4th, 2018, 20:08
Overland's Avatar
I look forward to trying the multi pass and see if it makes any difference.
Also, I seem to recall hearing somewhere that R12 hoses aren't perfectly compatible with R134a, that they leak down over time. I have one conversion going which I have to add a little to once a year, I wonder if that isn't it?
Old July 5th, 2018, 08:02
NAXJA Member #920
That doesn't ring a bell with me. The only time I've lost refrigerant in my 134-converted R12 system is when something truly failed (condensor rot, or rusted-out liquid line). No recollection of having leakdown.
1984 Dodge Omni
Old July 5th, 2018, 11:40
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
R152a is awesome. So far so good on my conversion on another vehicle.
I'm not sure what the bump is, but IIRC R134a introduction was 94 or 95.
Also, did you flush the old mineral oil out and add ester oil while doing your R152a conversion? You need to - mineral oil won't flow with R152a, gotta use ester oil, and it might be why your compressor is making noise now. If you open the system to replace the compressor and see "black death" black gunk or silvery metal debris, it's time to flush everything extremely carefully and replace anything you can't flush.
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old July 5th, 2018, 13:08
Overland's Avatar
Originally Posted by kastein View Post
...replace anything you can't flush.
This should be read as remove dash, remove HVAC cabinet, and replace evaporator. Then change the accumulator/dryer. The original condenser is single pass and can be flushed.
This is why people complain about the price of a shop replacing a compressor that trashed. It includes all of the above or the shrapnel will eventually circulate to an inevitable physical disagreement with the new unit, resulting in another failure in short order.
On this new '93-'04 Grand Cherokee gas tank recall thing... bradleyheathhays OEM Tech Discussion 5 June 12th, 2011 12:11
87 cherokee water line? chris y OEM Tech Discussion 30 January 14th, 2010 10:29
Best thing to line floor with. Roxtar Modified Tech Discussion 19 March 7th, 2006 20:19
98 Cherokee gas line pressure jp's xj OEM Tech Discussion 8 October 20th, 2005 10:02
last thing I need for my lift, BRAKE LINE winterparker2b Wanted: Private Party Only 0 February 14th, 2005 18:21
