OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
2000 XJ Front Brake Shield Question
What is the actual purpose of the brake shield on the front disk brakes? Is there any danger in leaving it off? Have any of you taken it off, if so did you encounter any problems with it off?
Thanks, Bill |
#2
Re: 2000 XJ Front Brake Shield Question
I don't run them with my WJ brakes, they have + and - points like getting a rock wedged there.
#3
Thanks for asking this oldbill !
My daughter went tearing things up in my 96 XJ and got a small peanut sized pebble stuck between the shield and the rotor, that thing made a god awful screech. I took that one off (haven't got to the other), but I'm wondering are yall putting in a washer to take up the room from not having the shield? |
#4
I removed mine when I had the 30 in there. Never had issues. Don't put any washers or anything in there. Don't grease the crap out of your joints or wipe any excess off to keep it off the rotor.
#5
Mine are off and no issues. Rust was eating them alive.
#6
As stated previously, they are there to keep debris from getting stuck in the brakes. Although they often cause that exact problem. In my years as an auto tech, I've seen many trucks roll in both with and without them. Neither way showed detrimental wear.
Short story...run em...don't run em...It don't make much of a difference.
.... ![]() 4shot "Babs" 97 sport 4.0 aw4 R.I.P."Buster" 86 laredo 2.8 ax5 10/85-9/17 In memory of Dave "Gonzo" Steele 1975-2008
#7
Ditch em
Sent from my SM-G975U using Tapatalk |
#8
I haven't run them in years, on multiple rigs.
The best benefit I ever saw from them was something to hit with a sledge to remove old unit bearings.
John V. RRC VP 01 XJ Sport 2 door 5spd/4WD- 4" lift, Rubi wheels/tires JCR bumpers/sliders, armor, Rubi 44, Ford 8.8, 4.56's, ARBs. |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
2000-2001 Jeep Cherokee Front Brake Pad & Rotor Kit Ceramic | 1ATony | Vendor Advertisements | 1 | October 11th, 2016 13:34 |
Brake dust shield? ??? | kenny811 | NorthWest Chapter | 11 | August 1st, 2013 10:31 |
Help: 89 XJ Front disk Brake Shield | XJBucko | OEM Tech Discussion | 3 | April 6th, 2011 13:17 |
brake dust shield | jeepnleo | OEM Tech Discussion | 4 | July 17th, 2009 18:52 |
D30 disc brake shield | twoksl2 | OEM Tech Discussion | 2 | May 14th, 2008 18:21 |
