Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > Red River Chapter
Red River Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Thread Tools Rating: Thread Rating: 28 votes, 5.00 average. Display Modes
  #8371
Old March 13th, 2019, 18:15
devildog0's Avatar
devildog0 devildog0 is offline
Re: What was done to YOUR rig(XJ/MJ) today MECHANICALY????
Originally Posted by OkieXJ View Post
I wouldn’t mind paying $350 to have new seals. How long did it take to take your doors apart and how difficult was it?
Couple of hours. Took about 2 to do the driver's side and about 1 to do the passenger side. Most of that time on the driver's side was figuring out what angle to get he windows out and what order everything needed to come out and go back in. Passenger side went much smoother.
https://youtu.be/dUAr4P1ND50
Sent from my SM-G892A using Tapatalk
1995 XJ Country/4.0L/AW4/231/UpCountry Suspension
2004 Suzuki DL650 VStrom/1978 Suzuki GS1000E/2003 Yamaha TW200
1982 Suzuki GS850G (barnfind project)
Old March 13th, 2019, 19:36
techno1154's Avatar
techno1154 techno1154 is offline
I replaced the Bilstein 5150's on the front of my XJ with some 5165's. The ride is much smoother, less jarring when it hit a rut and far less body roll. The bad? The 5165 have eye top and bottom. I had to use some adopters. That reduced my up travel by 1.5" +/- which is bad. I need to add another 1" of bump stop. Maybe I could use some shorter adopters. Some of those pieces that came on the XJ rear anti roll bar come to mind. I have to research the availability.
Previously, there were 4" up travel between the bump stop and the axle pad and 4.5" on the shock. The new shocks have 3.5" of up travel left.
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old March 13th, 2019, 19:44
OkieXJ's Avatar
OkieXJ OkieXJ is offline
Thanks for the video!
'91 Laredo 4.5" lift underway, 16" Moabs w/ Duratracks, Conn-Ferr rack, C4x4 front bumper, APN header, EBC pads and rotors, 8.8 swap, AA SYE & Tom Woods driveshaft.
'87 MJ with no drivetrain
Old March 14th, 2019, 09:10
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
I've been thinking of going with the 5165's or 7100's myself. Though I really don't want to reduce uptravel. Which adapters did you use?
John V.
RRC VP
01 XJ Sport 2 door 5spd/4WD- 4" lift, Rubi wheels/tires JCR bumpers/sliders, armor, Rubi 44, Ford 8.8, 4.56's, ARBs.
Old March 14th, 2019, 10:40
Crusher16's Avatar
Crusher16 Crusher16 is offline
RRC President
Dropped off the two driveshafts I have to get rebuilt and one shortened. Turns out the one that needed shortening was bent, so it needed retubing anyways. I'll be picking them up tomorrow!
1991 Briarwood
4 inches of upness | 4.56s | 33x12.50 KM2s | 8.25 with Disk Brakes | JKS HD XMember | JCR Front Bumper & Sliders | AJs Offroad Tanker Rear Bumper | NP242 - IRO HackNTap | Ironman4x4Fab UCAs & LCAs | Bilstein 5125s
Old March 14th, 2019, 12:04
R6TeXJ's Avatar
R6TeXJ R6TeXJ is offline
noice!
Old March 14th, 2019, 17:53
techno1154's Avatar
From 4 wheel parts, they are EXP 690001
Patrick
#594
Old March 15th, 2019, 07:09
Almost identical to, and half the price of the JKS ones, sweet!
John V.
RRC VP
Old March 15th, 2019, 07:12
So on Sunday I did some work on my front end. My coils were bowed so it was fairly crashy over bumps since I redid the axles 2 years ago. I don't know why it never clicked in my brain that I could adjust my adjustable control arms and fix that problem... had the lengths set based on the chart floating around online.
Lengthened the lowers half an inch and the uppers a quarter of an inch, and pulled the stock isolator to replace with a Daystar 3/4" lift spacer. Didn't finish Sunday as I ran out of daylight. Last night when I got home I torqued everything to spec and took it for a test drive.
I thought it was driving good before with the Deavers on the back. It's amazing now. The front springs actually spring. I've got better caster and therefore control. If I upgrade the shocks I think this thing will get even better!
Ready to go for ROM now.
John V.
RRC VP
Old March 15th, 2019, 08:24
Crusher16's Avatar
RRC President
Picked up the driveshafts that I had rebuilt. Going to slap one in the jeep in a little while and make sure 4lo works!
1991 Briarwood
Old March 15th, 2019, 11:49
R6TeXJ's Avatar
congrats man!
Old March 15th, 2019, 19:21
techno1154's Avatar
So there is someone who re-builds shafts in Garland. How much? I have one riding in the cargo area that needs rebuilt,...if the price is reasonable or I might buy a new one.
Patrick
#594
Old March 15th, 2019, 20:08
devildog0's Avatar
Hmm good question I work in Garland over off of Shiloh and Wood.
Old March 16th, 2019, 05:59
Crusher16's Avatar
RRC President
Drive train of Mesquite. It's about $100 for rebuild. A little more if the CV joint needs replacement parts.
1991 Briarwood
Old March 16th, 2019, 06:01
Crusher16's Avatar
RRC President
I think I recall seeing your Jeep over there. I live not far from there.
1991 Briarwood
Rate This Thread:
What was done to your rig today? A7XJ Arizona Chapter 1781 March 26th, 2016 21:13
In serious need of some help today. DrMoab Intermountain Chapter 16 November 30th, 2010 20:52
Tried out the TSL's today TheInstaller Jeep Picture Showcase 12 May 7th, 2007 22:16
new 37's came today!!! atowley Modified Tech Discussion 17 February 23rd, 2004 09:02
