Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > Red River Chapter
Red River Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Thread Tools Rating: Thread Rating: 28 votes, 5.00 average. Display Modes
  #8281
Old February 3rd, 2019, 20:15
denverd1 denverd1 is offline
Re: What was done to YOUR rig(XJ/MJ) today MECHANICALY????
Originally Posted by R6TeXJ View Post
haha where'd you get those bumps from, which trails?
Looks like it's still wet out there. Those trails that are usually easy turn into an ice skating rink lol
only a few wet spots. founds some mud at the back close to sierra skyline. it drains out pretty quickly. not sure where I cracked the taillight....
Old February 4th, 2019, 08:43
R6TeXJ's Avatar
R6TeXJ R6TeXJ is offline
Aww ok, Yeah it's been a hot moment since I've been able to go out that way.
Hopefully will hear from the driveshaft shop today about my front driveshaft. Not sure if my front shaft needs to be replaced or if my pinion angle on the front needs to be addressed.
Old February 4th, 2019, 10:55
Crusher16's Avatar
Crusher16 Crusher16 is offline
RRC President
Returned the Bosch O2 sensor I put in. Got an NTK O2 sensor coming today.
Is it normal for the CEL to NOT turn on when O2 sensor is disconnected?
1991 Briarwood
4 inches of upness | 4.56s | 33x12.50 KM2s | 8.25 with Disk Brakes | JKS HD XMember | JCR Front Bumper & Sliders | AJs Offroad Tanker Rear Bumper | NP242 - IRO HackNTap | Ironman4x4Fab UCAs & LCAs | Bilstein 5125s
Old February 4th, 2019, 16:50
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
How long did you run it?
John V.
RRC VP
01 XJ Sport 2 door 5spd/4WD- 4" lift, Rubi wheels/tires JCR bumpers/sliders, armor, Rubi 44, Ford 8.8, 4.56's, ARBs.
Old February 4th, 2019, 17:06
techno1154's Avatar
techno1154 techno1154 is offline
So there is a place to repair drive shafts? There is a place in New Braunfels that advertise on line that they do re-gearing and drive shaft repair. I talked with them about a shaft carried in the back of the XJ from Florida that I would like to get repaired. Spoke with them, price is $480+. Adams Driveshaft sell a new unit for about $300 +/-. And they could regear both axles for $3500.
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old February 4th, 2019, 18:01
R6TeXJ's Avatar
This place said a new shaft would be about $300 as well.
neither of them say what thickness of metal is used for the driveshaft...oh I didn't hear anything from them today.
Old February 4th, 2019, 18:18
Crusher16's Avatar
RRC President
For about a minute. Maybe didn't let it run long enough.
Slapped the NTK o2 sensor in earlier. Just got done test driving it and it seems to be fine now. Got it over 80mph without a hickup and it seems to be idling smoother. There is still a very very small shutter while idling, but I can live with it for now.
Or the Jeep really hates below 40 degree weather. We'll see. :shrug:
On ward to extracting a broken bolt on the front pinion yoke so I get the front drive shaft in. Then it may be time to do a run to Bridgeport to stretch its legs.
Really wanting to put the 33s I got on. But that means its time to cut the fenders. Not sure I'm ready for that still.
1991 Briarwood
Old February 4th, 2019, 18:58
Closed loop mode if it wasn’t warmed up. Sensor is irrelevant at that point
John V.
RRC VP
Old February 4th, 2019, 19:07
Crusher16's Avatar
RRC President
That makes sense
1991 Briarwood
Old February 5th, 2019, 19:11
devildog0's Avatar
devildog0 devildog0 is offline
That makes sense
Yeah the O2 only comes into play at idle and cruise when up to temperature. All other modes use all the sensor BUT the O2 sensor. At least on OBD1 models.
Sent from my SM-G892A using Tapatalk
1995 XJ Country/4.0L/AW4/231/UpCountry Suspension
2004 Suzuki DL650 VStrom/1978 Suzuki GS1000E/2003 Yamaha TW200
1982 Suzuki GS850G (barnfind project)
Old February 6th, 2019, 07:50
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Yes and no. OBD-II it should show and CEL pretty soon, but not sure how soon. I had a 96 Ford that never threw a code and never would lock in the emissions stuff and go green, that had one spark plug wire not connected for hours of tests.... so it was stuck in final test mode. Never set off the CEL or codes, was stuck between green and red with a yellow light on the code scanner.
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old February 6th, 2019, 07:53
Ecomike's Avatar
NAXJA# 2091
Typo???
Closed loop uses the O2 sensor data. Open loop tries to use O2 sensor as it tries to switch to closed loop. While trying it can have trouble and have issues and finally give up and revert to open loop.
Open loop is start up cold, and at WOT. The electric heater in the O2 sensors is to speed up warming up the O2 sensor to get into closed loop faster, and the sensor tech does not work if below about 600 F.
Old February 6th, 2019, 07:58
Ecomike's Avatar
NAXJA# 2091
Once in closed loop, it stays there, except at WOT. During rapid-full Decel the ECU cuts off fuel, and thus does ignore the O2 data, but the ECU still reads it. During normal acceleration, deceleration (not using the brake lets say) it is closed loop.
In park I can slam the gas pedal and run the engine up to say 3500 rpm in about 1-2 seconds, and it stays in closed loop. Renix 87. Its only about 30% of WOT then. At least that is what my scanner says and FSM
Old February 6th, 2019, 09:54
Originally Posted by Ecomike View Post
Typo???
I get them backwards. Dyslexia.
Either way the O2 is irrelevant when not warmed up.
John V.
RRC VP
Old February 6th, 2019, 09:55
Deavers and Napier flares show up today.
The rest of the week will drag because I have parts to install.
John V.
RRC VP
Rate This Thread:
What was done to your rig today? A7XJ Arizona Chapter 1781 March 26th, 2016 21:13
In serious need of some help today. DrMoab Intermountain Chapter 16 November 30th, 2010 20:52
Tried out the TSL's today TheInstaller Jeep Picture Showcase 12 May 7th, 2007 22:16
new 37's came today!!! atowley Modified Tech Discussion 17 February 23rd, 2004 09:02
